Engine Stalling at 60 mph #952815
03/17/11 09:19 PM
03/17/11 09:19 PM
Louisiana
duckblind Offline OP
Louisiana
I am helping my buddy with his 70 charger. It has a 440/4 spd. We just put the engine in and am trying to get it tuned right. It has a mopar electronic distributor with vacuum advance, stock build engine, electric fuel pump. The timing is set at 14 BTC. Everything runs fine but the engine stalls out at around 60 mph. Any ideas what could be causing this?
Re: Engine Stalling at 60 mph [Re: duckblind] #952816
03/17/11 09:22 PM
03/17/11 09:22 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Dirty fuel filter or the sock-strainer on sender is plugged a bit. Kinked fuel bhose another possibility.
Re: Engine Stalling at 60 mph [Re: buildanother] #952817
03/17/11 09:55 PM
03/17/11 09:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
lack of fuel if the car runs fine to that speed. may be carb floats set to low.
Re: Engine Stalling at 60 mph [Re: stumpy] #952818
03/17/11 11:20 PM
03/17/11 11:20 PM
Louisiana
Louisiana
I will try and troubleshoot the fuel system. The electric fuel pump is new and the filter upstream of the pump is new. However, the sending unit has not been changed so maybe there is crud in it.
Re: Engine Stalling at 60 mph [Re: duckblind] #952819
03/17/11 11:21 PM
03/17/11 11:21 PM
We just put the engine in. Everything runs fine but the engine stalls out at around 60 mph.
More details, was the eng OK b 4 (if so what was changed) or if another eng was it OK w this elec pump setup? Is that cruise or WOT at 60 MPH. What carb? What they said, check float level/filter(s) (inline and carb internal) and might put a T at the carb inlet & run a line to a vacuum gauge taped to your windshield & see if have several PSI at the offending sp (60MPH), Most of the hand held type vac gauges have a PSI side for pumps EDIT read your last post, might put a can of gas in the trunk & run a section of neoprene line down to the line at the sending unit to bypass the tank & take her back out & you'll know immediately if the sock is partly plugged.
Re: Engine Stalling at 60 mph [Re: RapidRobert] #952820
03/22/11 07:58 AM
03/22/11 07:58 AM
Louisiana
Louisiana
The problem ended up being a bad fuel pump. Also, the flow out the tank when we had the pump inlet hose disconnected was a little intermittent so we blew back up the line into the tank. After this, it looked like we had better flow. Maybe the sock filter is a bit dirty and that caused the pump to go bad. I guess the next thing on the list of things to do is change the sock filter in the tank to keep this from happening again.
Re: Engine Stalling at 60 mph [Re: duckblind] #952821
03/22/11 10:09 AM
03/22/11 10:09 AM
Under My Car
Mopar_Country Offline
Under My Car
If the tank has not been taken out and cleaned I would suggest looking into that. You might cut the filter open and look at it, if it is excessively dirty then I would clean the tank and replace the sock. I just went through this with my car yesterday and the sock was disintegrated and allowing garbage to be sucked up the line. My car would seem to run out of energy under hard acceleration. You would be amazed at the amount of crud that's in there.
Re: Engine Stalling at 60 mph [Re: duckblind] #952822
03/22/11 10:32 AM
03/22/11 10:32 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have a new 3/8 sending unit if ya need one. Also no need for an electric pump on that car. Just go to NAPA and get the pump they have listed for a 440-6 car and roll.
Coming soon!!!!
