Installing Factory E-body rear sway bar question #952729
03/17/11 08:41 PM
03/17/11 08:41 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
I'm putting a factory rear sway bar on my 70 Challenger. The car did not have the dimples on the frame rail where the sway bar frame brackets bolt. So what is the best way to install the bar to ensure I'm putting the frame bracket mounting holes in the correct location?
Thanks, Joe
65 Barracuda
70 Challenger
Re: Installing Factory E-body rear sway bar question [Re: jrwoodjoe] #952730
03/17/11 08:43 PM
03/17/11 08:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It'll will line up it's self when you get it all togeather.
Re: Installing Factory E-body rear sway bar question [Re: Challenger 1] #952731
03/17/11 10:32 PM
03/17/11 10:32 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
sometimes the dimples are there under the paint and undercoat...they are very small indents..
Re: Installing Factory E-body rear sway bar question [Re: AARCONV] #952732
03/17/11 11:00 PM
03/17/11 11:00 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Joe here is a shot of my Sway bar. Holes were drilled at the factory on mine. I agree just bolt the end links in place and it all should just fall into alignment.
Dennis
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Installing Factory E-body rear sway bar question [Re: 19cuda73] #952733
03/18/11 10:55 AM
03/18/11 10:55 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The frame brackets are tapered to match the frame. They will align themselves.
Re: Installing Factory E-body rear sway bar question [Re: jrwoodjoe] #952734
03/18/11 01:12 PM
03/18/11 01:12 PM
cataclysm80 Offline
cataclysm80  Offline
The early cars may not have dimples.
I will be doing this myself on my Challenger. I have a 'Cuda here with factory rear bar for measuring, but couldn't find any good reference points to measure from.
For the bar to align itself, does it make a difference if the cars weight is on the leaf springs? (do this with the car jacked up, or on the ground?)
Tav
Re: Installing Factory E-body rear sway bar question [Re: burdar] #952735
03/18/11 01:53 PM
03/18/11 01:53 PM
Cincinnati, Ohio
Cincinnati, Ohio
