Green Bearings on abody question #952691
03/17/11 06:50 PM
03/17/11 06:50 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
If I had an A-body 8-3/4 rear, all stock. Could I switch to green bearings by just removing my tapered rollers and pressing on the greens ?
Or do I also have to, either remove the thrust pin from my center chunk, or have the axles shortened ?
Re: Green Bearings on abody question [Re: MileHighDart] #952692
03/18/11 12:43 AM
03/18/11 12:43 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Snap ring style green bearings do not require differential thrust block removal.
Re: Green Bearings on abody question [Re: DoctorDiff] #952693
03/18/11 12:51 AM
03/18/11 12:51 AM
Lyons, CO
Lyons, CO
Thanks Cass,
I know I can get the green bearings online, mancini, moser, etc, or probably from you, But do you know if they can be bought at the local Napa, Advance auto type places ?
I'd like to get them local if possible, just cause I want to get my project finished up asap.
