rear brake drum full of diff fluid #952530
03/17/11 11:31 AM
03/17/11 11:31 AM
Mass
68bb Offline OP
super street
68bb  Offline OP
super street
Mass
Rear is an 8 3/4 in a Dart. Looks like there is an inner and outer seal. I replaced the outer seal last year but not the inner. Would it be correct to assume that since fluid is getting out to the drum that the inner is most likely at fault? Looks like manual says press is needed to replace inner?
thanks
Re: rear brake drum full of diff fluid [Re: 68bb] #952531
03/17/11 12:35 PM
03/17/11 12:35 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Or you have too much fluid in the pumpkin.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: rear brake drum full of diff fluid [Re: 68bb] #952532
03/17/11 12:48 PM
03/17/11 12:48 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Bad inner seal allows oil to get to the brake, replacing outer seal requires a press, the lock collar and brg must be removed from the axel this frees the seal retainer.
Re: rear brake drum full of diff fluid [Re: 68bb] #952533
03/17/11 01:08 PM
03/17/11 01:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Tony , if the part of the axle the bearing rides on is pitted it will leak . You can put a redi-sleeve on it , I did it on an axle for someone a few years ago , no leaks I had the drums off the car last fall.
Re: rear brake drum full of diff fluid [Re: JohnRR] #952534
03/17/11 02:03 PM
03/17/11 02:03 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
possibly the vent is clogged.. ck that first!
Re: rear brake drum full of diff fluid [Re: ph23vo] #952535
03/17/11 02:23 PM
03/17/11 02:23 PM
Mass
68bb Offline OP
super street
68bb  Offline OP
super street
Mass
Hmmmmmm.....I have noticed there has been some fluid coming out the vent.
Re: rear brake drum full of diff fluid [Re: 68bb] #952536
03/17/11 04:12 PM
03/17/11 04:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If there is fluid coming out the vent it's over filled .
Re: rear brake drum full of diff fluid [Re: JohnRR] #952537
03/17/11 05:21 PM
03/17/11 05:21 PM
Mass
68bb Offline OP
super street
68bb  Offline OP
super street
Mass
That's what I am going to check next. Sounds like I may have created my own troubles.
