PUSH BUTTON 727 HI PO REBUILD PARTS #952463
03/17/11 10:34 AM
03/17/11 10:34 AM
Central New York
bfury Offline OP
bfury  Offline OP
Central New York
Does anyone know a company that sells high performance rebuild parts for a '63 push button 727 for a BB. I will be using behind a 450 HP 440.I haven't seen anything listed for these years with Turbo Action, B&M or A&A. Any suggestions?
No Stock
Re: PUSH BUTTON 727 HI PO REBUILD PARTS [Re: bfury] #952464
03/17/11 12:19 PM
03/17/11 12:19 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
NOTHING really special about the PB TF except the VB and a couple of diff gaskets.
I think there is someone on-here that is a sponsor that can cope with your request.
Re: PUSH BUTTON 727 HI PO REBUILD PARTS [Re: dOc …] #952465
03/17/11 12:23 PM
03/17/11 12:23 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
No but, I have t-shirts for the pushbutton fan !
Re: PUSH BUTTON 727 HI PO REBUILD PARTS [Re: bfury] #952466
03/17/11 04:26 PM
03/17/11 04:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A lot of rebuild kit makers offer a supplemental kit to go along with the '71-later rebuild kits, the supplemental kit has the gaskets and sealing rings needed for the PB trans.
Board member John Cope (CRT) should be able to fix you up.
Re: PUSH BUTTON 727 HI PO REBUILD PARTS [Re: John_Kunkel] #952467
03/20/11 05:37 PM
03/20/11 05:37 PM
Central New York
bfury Offline OP
bfury  Offline OP
Central New York
Thanks! I sent an e mail and hope for the parts I need.
No Stock
Re: PUSH BUTTON 727 HI PO REBUILD PARTS [Re: bfury] #952468
03/20/11 05:45 PM
03/20/11 05:45 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
The PB 727 has a rear pump that the later cars don't. You can actually push start one of these but it's not as easy as a stick.
