Quarter window replacement help needed.......... #952455
03/17/11 08:18 AM
03/17/11 08:18 AM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
I'm in the process of working my way through the windows on my restoration.
The passenger side rear quarter window is nice (just needs to be cleaned up) but needs to be reinstalled in the window channel.
Is there a glue or adhesive strip used to do this? Is it applied to the horizontal channel and the vertical channel too?
Here's a pic of the window just sitting in.
thanks
Tom
Re: Quarter window replacement help needed.......... [Re: Finoke] #952456
03/17/11 08:19 AM
03/17/11 08:19 AM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Here is a picture of the window channel on the frame.
Re: Quarter window replacement help needed.......... [Re: Finoke] #952457
03/17/11 08:20 AM
03/17/11 08:20 AM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
and another
Re: Quarter window replacement help needed.......... [Re: Finoke] #952458
03/17/11 12:02 PM
03/17/11 12:02 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I took mine to a glass guy, who used an epoxy to re-set the parts. In an e-body there is a pot metal lower attaching bracket that needs to be very securely attached to the glass. I had the stainless steel parts polished first and used new glass.
