stock rockers w/Comp Cam XE294 #952269
03/16/11 10:13 PM
03/16/11 10:13 PM
Colorado
67plymouthman Offline OP
Colorado
I am curious if I can run stock rockers on my 440 with the Comp Cam XE294. The cam specs: 250 and 256 @ 50 the lift is 519 and 524. The motor is 60 over and the heads have been milled 20 thousands- I should be around 12:1 with my domed pistons. I am running a 4,000 stahl, headers and 4.10s. I know a lot of people run stock rockers with the .509 cam. I know that I can run a bigger cam with the compression that I am running but I also want to street the car occasionally and I will be running E85. I live at 4,000ft altitude.
Re: stock rockers w/Comp Cam XE294 [Re: 67plymouthman] #952270
03/16/11 10:34 PM
03/16/11 10:34 PM
IN
ahy Offline
ahy  Offline
IN
It might work for a while... stock rockers over about .5 lift seem like a big risk though and the possibility of serious and expensive engine damage with failure doesn't seem worth it. If budget limits to stock rockers better to go with a 509 or a more moderate comp grind.
Re: stock rockers w/Comp Cam XE294 [Re: 67plymouthman] #952271
03/17/11 02:00 AM
03/17/11 02:00 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
My kid's running stock rockers with the XE284....and we both have fits about them maybe not surviving.
I think you're pushing your luck myself especially if you're panning to do some serious rpms. Spring pressure could be an issue.
With the parts that you already have working together in there now, why are you considering this?? Budget???
Re: stock rockers w/Comp Cam XE294 [Re: superwrench] #952272
03/17/11 02:19 AM
03/17/11 02:19 AM
Renton Washington
Triple Threat Offline
Renton Washington
We're running that cam with stock rockers and pushrods in one of our cars. A 440 Challenger its got maybe 150 passes on it, not many street miles. It did shove a pushrod through a rocker once. Lifter popped out, lost oil pressure yada yada. Replaced the parts with other stock junk we've got lying around. Still runs 11.90-12.1 as always. FWIW we shift the car at 5600 and the limiter is at 6400.
I dont recommend it. But if thats what the budget calls for then it will have to work.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: stock rockers w/Comp Cam XE294 [Re: Triple Threat] #952273
03/17/11 05:40 PM
03/17/11 05:40 PM
Colorado
Colorado
Ya- I am trying to budget my racing expenditures
What rockers would you recommend? That are budget friendly?
Re: stock rockers w/Comp Cam XE294 [Re: 67plymouthman] #952274
03/17/11 06:06 PM
03/17/11 06:06 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I ran stock rockers with a lunati voodoo 60303 226/234@050, 494/513 lift if memory serves. Has steeper lift per duration than the cam you're looking at. I'd think lobe rate combined with valve spring stiffness would make the difference. I was running the stock 440source stealth head valve springs with mine.
Re: stock rockers w/Comp Cam XE294 [Re: 67plymouthman] #952275
03/17/11 06:06 PM
03/17/11 06:06 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Those 2 questions should not be strung together , you may as well roll the dice and run stock rockers if you are going to cheap out , the damage from breaking a stock rocker is cheaper than a cheap roller tip that loses the roller wheel and drop your valve into the cylinder .
Re: stock rockers w/Comp Cam XE294 [Re: JohnRR] #952276
03/17/11 07:13 PM
03/17/11 07:13 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Are the Crane ductile iron rockers being produced? They seem to have been the old reliable for decades.
Keep old mopars alive.
Re: stock rockers w/Comp Cam XE294 [Re: 2boltmain] #952277
03/17/11 11:49 PM
03/17/11 11:49 PM
Central NC
gch Offline
gch  Offline
Central NC
Score a set used with shafts and maybe get lucky with pushrods too.Or at least buy the new stock rocker package that are supposedly thicker.
Re: stock rockers w/Comp Cam XE294 [Re: gch] #952278
03/18/11 01:24 AM
03/18/11 01:24 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I've always figured the max. threshhold of stock rockers is about .500 lift. Spring pressures are a consideration as well. It may work for a while, but I think its a borrowed time situation. You're certainly putting excessive wear on your valveguides.
I hesitate to say it, but.... I'm having good luck with my ProComp steel rollertip rockers. (Let the Moparts flaming begin ) They're on their second motor, first was a .496 lift juice cam 383, now they're atop a .573 lift solid. I've done two rocker gear check / adjusts since the motor was new. No problems whatsoever. They can be had for about $250 on ebay. There's also a couple of sets of ductiles on ebay right now (one brand new set).
Re: stock rockers w/Comp Cam XE294 [Re: StealthWedge67] #952279
03/18/11 01:44 AM
03/18/11 01:44 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
With .020 off the head and no adjustment in the valvetrain.... I would go with a adjustable rockers.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: stock rockers w/Comp Cam XE294 [Re: gch] #952280
03/18/11 08:58 AM
03/18/11 08:58 AM
Australia
Charger VJ RB Offline
Australia
Yep thats what I bought, One person I know has run 557 lift cam with stock rockers, custom pushrods and been ok, however regular checks would be worth it.
RB XE274H Q-850
Re: stock rockers w/Comp Cam XE294 [Re: gch] #952281
03/18/11 09:05 AM
03/18/11 09:05 AM
JohnRR Offline
JohnRR  Offline
I just got thru messing with the new stock rocker package , the side clearances range from .011 to .047 ... uuggghhh
I agree with finding a used set of cranes or better yet real isky's , check them for galling though ...
