Re: Quarter Panel Stress Cracks---69 Coronet 500 conv.
[Re: Chatt69chgr]
#952264
03/17/11 02:47 PM
03/17/11 02:47 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
If you've got a B-body convertible, you've probably got these cracks. Very common.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: Chatt69chgr]
#952265
03/17/11 02:52 PM
03/17/11 02:52 PM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
My little '68 a-body has them too. US Cartool subframe connectors help lots.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: topside]
#952267
03/17/11 04:07 PM
03/17/11 04:07 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
There was also a problem with the rear shock crossmembers tearing away from the trunk floors on some cars, had a '68 like that.
I've only ever seen or heard of that on cars that had air shocks , the shock crossmember was not designed to support the weight of the rear of the car 24/7.
