Re: Tow vehicle questions
[Re: MadMez]
#952235
03/16/11 09:01 PM
03/16/11 09:01 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
It really depends very much on how much weight you will be towing and if you need to be able pull a hill or two on the way. I now have a 2002 3/4 ton Cummins TD and would never go back to a gas motor for a tow vehicle. I used to tow a 68 Coronet on an open trailer with a '71 Fury Wagon and while it was OK for a 50 mile trip one way, when I took the car on a 200 mile tow it was miserable. The wagon's rear suspension was not firm enough to prevent sway and the 360 V-8 was not happy with the load. With the Cummins I pull a 8,000# travel trailer with ease and the mountain passes in Washington don't slow me down at all. You can never have too much tow vehicle! BTW I am 64 and am building a drag rig again, too!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: MadMez]
#952238
03/16/11 09:18 PM
03/16/11 09:18 PM
Posts: 114 Nevada
Darter6
Nevada
Wow,, you sound like me. Split with the wife after 23 years and the first thing I did was to start racing again. Went through 3 tow vehicles before I got the right one. Are you using a open trailer ? Closed ? What length ? What do you plan to take with you ? Weigh everything,Trailer,Car,Tools,Fuel,ETC. You will be suprised what you come up with. I started out with a Jeep Grand Cherokee,1/2 ton Dodge,3/4 ton V10 Dodge,Then the truck that I should have had first. 1 ton Diesel dodge.From the begining had a 24 foot enclosed trailer with a 7000 lbs rating.I was always at the limit or over. Used Diesel dodge trucks can be had for a good price. I just got a 1 Ton 92 4 wheel drive with 260,000 miles on it for 3 grand. Found it on local Craigs List. 1 owner everything works and was well maintained. Take your time and do some looking. I also feel safer with something that can handle a load and will stop with ease. Sorry for the long rant but this is what I went through. Oh and just remember that you don't mind going slow but the other crazy ass drivers out there WILL cut you off,pass when they shouldn't and slam on the brakes in front of you because you held them up for a minute or two. So get out there and have some fun damn it !!!!!
[Re: MadMez]
#952239
03/16/11 09:28 PM
03/16/11 09:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You might look at V-8 van... like you said you can sleep in it.... a EQ hitch for any of them and you should be set
[Re: MadMez]
#952240
03/16/11 09:47 PM
03/16/11 09:47 PM
Posts: 16,928 NC
440Jim
NC
I have been towing my open trailer and race car with 1-ton cargo vans for years. I currently use a 2005 Ford E-350 with the 5.4 engine and 3.73 gears, 4-speed OD automatic. This works just fine. I am not a fan of the Ford 4.6 engine for towing, but around town on flat roads for short distances it might be minimally acceptable, but not recommended IMO.
For many years (~1997-up, including 2005) the 5.4 in the cargo vans was the 2-valve version, not the 3-valve version that comes in many 1/2 ton (F-150) pickup trucks. The 2-valve version is a lower rpm engine, good for towing. It makes about the same peak torque as the 3-valve (350-365), but at ~2500 rpm not ~3750 rpm. Of course, the 3-valve makes more peak hp (~300 hp at 5000, compared to 255 hp at 4500 rpm.
I used to have a 1994 Dodge B-350 with the 5.9 engine and 4.10 gears, A518 (4-speed OD auto). With the open trailer, it worked fine too.
I have slept in the back of my van at multiday races a lot over the years; as long as the track has showers. Cheap... LOL
[Re: MadMez]
#952241
03/16/11 09:52 PM
03/16/11 09:52 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
How far will you have to tow? If it's only a 100-150 miles round trip, I wouldn't sweat it too much with an open trailer under 5000 lbs. Use an equalizer and 4 wheel trailer brakes with a Prodigy controller. Drive near the limit, and let the "in a hurry to get nowhere" crowd blow by. Remember, after you hook up the trailer fully loaded, only you will be the final judge on how safe or reliable it feels. A 3/4 ton minimum, is the desired deal, but a budget is a budget. Good luck! Leigh
[Re: pro6pakRR]
#952243
03/17/11 02:18 PM
03/17/11 02:18 PM
Posts: 260 Slinger WI
MadMez
Slinger WI
Thanks for all the replies guys! I will be pulling my 64 Dodge on an open trailer. Two tracks are local to me, Great Lakes Dragaway and Wisconsin International Raceway, I am in between them. No long trips this year, staying local. I will keep an eye out for a used diesel truck but I also like the van idea. Then I will have a place to live down by the river! I hope to be able to start racing by the end of June.
[Re: MadMez]
#952244
03/17/11 06:11 PM
03/17/11 06:11 PM
Posts: 7,506 Az
Crizila
Az
I tow with a 05 Jeep Grand Cherokee 5.7 Hemi. It's at the GVWR limit with my rig, but it tows good, especially if you are flat landing. Hills it's ok - you will be in 3rd gear a bit. Mountainous terrain, it's hurtin a little and you will be in 2nd gear at times. Still a good trade-off vehicle though. A load distribution hitch is about manditory if you are near the GVWR.
Fastest 300
[Re: Crizila]
#952248
03/17/11 09:35 PM
03/17/11 09:35 PM
Posts: 396 California, USA
Phil Saran
California, USA
You've been given good advice, can I add a little more for you to chew over?
Diesel truck (what ever is your favorite & price) then add a cab over camper (8ft) with a wet bath. Then you have a place to sleep and also cook and take a shower. If you shop around a used camper can be had for a fair price. If you go bigger than 8 ft then you get into hitch extensions and the price goes up FAST. Just ask how I know this.
My tow rig is a 2004 Ford F350 diesel with 9'-11" cab over camper and I tow a 18 ft open car trailer with 4 wheel electric brakes.
Also make sure what ever vehicle you buy has (or add) a brake controller and that the car trailer have 4 wheel brakes on it.
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#952249
03/17/11 09:55 PM
03/17/11 09:55 PM
Posts: 7,506 Az
Crizila
Az
Don't know if you have other transportation, but just remember what you are stuck with when you are not towing, which is 95% of the time.
Fastest 300
[Re: MadMez]
#952251
03/18/11 02:11 AM
03/18/11 02:11 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
My Get an '02 or older dodge diesel. Stay far far away from the ford 6.0, 6.4 and even the chevy duramaxes. Though they do work well, when they work. When they break, they break the bank. And they will break. The '03 and newer cummins trucks need to have 5-7 micron or smaller fuel filters in them and have them replaced frequently (as in every to every other oil change). When the injectors go bad, it's 3300 or more to get them replaced where I work, and we're reasonable. If you can find a 3/4 ton gas powered truck, (I'll probably get flamed for saying this) the general's offering with the 6.0 gas motor isn't a bad truck. When dodge quit offering an engine over 350 cubic inches in pickups, I kinda lost interest. The V10's sound like they belong in delivery vans (IMO) and tend to like the gasoline. I simply hate the way ford engineers any of their newer crap. Don't get me wrong, they do tend to last fairly well, but the 2 valve heads like to blow spark plugs out if the threads show any sign of abuse (not to mention they flow less than 170 cfm stock, not a real power maker there) and the 3 valve heads use some super deep special spark plug that gets carbon around the base and breaks off when you try to remove them. Way to go ford engineers. So, to summarize, (again, IMO) if you get a diesel, the only option is a cummins and if you want a gasser, I prefer the generals with the 6.0 LS motor.
