2.25" vs. 3" air cleaner #952203
03/16/11 08:34 PM
03/16/11 08:34 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I have a 3"x14" K&N round drop base air filter in place now and was thinking of trying a 2.25"x14" to make room for a 1/2 open carb spacer. Do you think the reduced surface area of the air cleaner will make any noticeable difference when running on the street? At the track I pull the filter so it won't make any difference there.
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: 2.25" vs. 3" air cleaner [Re: tywebb2] #952204
03/16/11 09:38 PM
03/16/11 09:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Wont be any different... your at part throttle MOST
of the time
Re: 2.25" vs. 3" air cleaner [Re: MR_P_BODY] #952205
03/17/11 12:29 AM
03/17/11 12:29 AM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
I'd be way more worried about top of carb to lid area than element area.
Re: 2.25" vs. 3" air cleaner [Re: Cuda367] #952206
03/17/11 08:49 PM
03/17/11 08:49 PM
Central NC
gch Offline
gch  Offline
Central NC
Try them both back to back(with cool down in between)at the track and see for yourself.
As stated,on the street it won't make a bit of difference in normal driving.
Re: 2.25" vs. 3" air cleaner [Re: tywebb2] #952207
03/18/11 09:26 AM
03/18/11 09:26 AM
Australia
Charger VJ RB Offline
Australia
Quote "For performance applications, you should shoot for a pressure loss in the 0.5% to 1.0% range at the peak power rpm. Less is
better".
http://www.secondstrike.com/Technical/AirCleanerHelp.pdf
Page 4 PDF or page 20 article "Typical Results"
Warning ford related but it may give you some info on air cleaners.
RB XE274H Q-850
