You guy's ever had problems with...
#951996
03/16/11 01:54 PM
03/16/11 01:54 PM
dartman366
Mt. Vernon, Ohio
stainless hose fittings leaking? was about to fire up the car and purged the fuel system to fill the carb and several of the -08 an 90 degree swivel fitting's started spewing at the swivel part,,,,do they ever come out of it or is it time to order new one's,,I figure the O ring's have shrunk from the fuel.
Re: You guy's ever had problems with...
[Re: dartman366]
#951999
03/16/11 02:52 PM
03/16/11 02:52 PM
Posts: 43,289 Bend,OR USA
Cab_Burge
Stainless covered neopreme hoses leak after a while The Teflon I use has not yet, some of it is over ten years old I don't know about the swivels O rings
[Re: dartman366]
#952001
03/16/11 08:08 PM
03/16/11 08:08 PM
I just had 2 Russell Swivel Fitting leak also. They were the -10AN ones. Came right out of the small hole. and out the swivel part. I'm only using Fragola from now on and Aeroquip.
