VIN number question-on the block #95150
07/26/08 09:34 PM
07/26/08 09:34 PM
middle of the country
aar1 Offline OP
aar1  Offline OP
if the vin number stamped on the block is 0E123456, that would be for a 1970 E-Body, correct? Is it possible that there was a Cuda and a Challenger produced with the same VIN numbers stamped in the block (assuming their sequence numbers were the same)?
Doesn't the 0E (zero, e) mean it came out of a 1970 E=body? THANKS!!
Re: VIN number question-on the block [Re: aar1] #95151
07/26/08 09:57 PM
07/26/08 09:57 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
1970 is correct, but E is for the Los Angeles plant. That letter is for the plant.
Careful, your character's showing!
Re: VIN number question-on the block [Re: mopar346] #95152
07/26/08 11:24 PM
07/26/08 11:24 PM
aar1 Offline OP
aar1  Offline OP
so the letter is the plant, not the body style of the car. So if the vin on the block is 0E12345, that would have been any 1970 car built at the L.A. plant? I know they built Cuda's there, what else?
Re: VIN number question-on the block [Re: aar1] #95153
07/26/08 11:27 PM
07/26/08 11:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 LA cars;
A, B & E bodies.
If you have the whole VIN on the engine I can check my files and see if I know what it came from.
Re: VIN number question-on the block [Re: aar1] #95154
07/27/08 07:42 PM
07/27/08 07:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what size engine ? no big blocks in A bodies in 70 so it would rule them out if its a big block , no 340's in 70 b bodies so it would rule them out if it's a 340 ...
Re: VIN number question-on the block [Re: JohnRR] #95155
07/28/08 01:37 PM
07/28/08 01:37 PM
aar1 Offline OP
aar1  Offline OP
so if it's a 440 block it would either be a B or E body.
Re: VIN number question-on the block [Re: aar1] #95156
07/28/08 03:33 PM
07/28/08 03:33 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Or a "C" body, but not sure they built them in LA.
The sequence number is 1 2 3 4 5 6 ??? I guess a car somewhere had to have that number.
