I have a CH440 intake with a dominator flange. I intend to give it a try when I detune a tunnel ram, 12:1, 440 that I had for my rail. I'm obviously expecting a loss in peak hp, but I do expect it to look fairly stock in my Challenger.
The intake in the magazine article has a cast in belly pan. Mine does not. I also think the test article does not give the intake any fair consideration. The test piece had the divider milled down old school style, which is an attempt to make it a better single plane, rather than good dual plane intake. I expect my intake to be at least on par with a Performer RPM, with perhaps a little more top end with a dominator carb.
I also made my own dominator to 4150 4 hole spacer/adapter to try my 1000 cfm HP 4150 carb and do back to back comparisons.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
