F150 rear axle #951304
03/15/11 05:03 PM
03/15/11 05:03 PM
somewhere out there
Billy no mates Offline OP
somewhere out there
Hi Guys,
I have the chance of buying a 9 3/4 out of a f150 with 373 gears & a locker. Would this axle be a Dana 60? other than spring perch location & width does anyone forsee any other problems I will have putting it in a early B body.
thanks Billy
BillyNoMates
Re: F150 rear axle [Re: Billy no mates] #951305
03/15/11 05:13 PM
03/15/11 05:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
F150 wouldn't have a 9.75... F250 & 350 from the 70's might... If it's a 83 or newer F150 it has a 8.8 which 3.73 & locker was common in...
Re: F150 rear axle [Re: 1_WILD_RT] #951306
03/16/11 03:12 PM
03/16/11 03:12 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
A 1997? or newer F150 could have a 9.75 axle. My truck does. I saw one site that said it is equivalent to a Dana 60. I don't know but it does look similar.
Read this. http://www.fourwheeler.com/techarticles/drivetrain/129_0802_ford_f150_975_axle_build/index.html
1970 Dodge d100/eventually going on a 77 D100 frame
Re: F150 rear axle [Re: Billy no mates] #951307
03/16/11 03:35 PM
03/16/11 03:35 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Many F150s from the late 90s and newer have Dana 60s in them. I worked at a Ford store for a while and thought about doing the same swap in the hot rod.
- Stu Harmon
Re: F150 rear axle [Re: feets] #951308
03/16/11 03:58 PM
03/16/11 03:58 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Just because it has a 9 3/4 diameter ring gear does not make it a Dana 60. It is not. Did you read that article above? They are simply saying that they think it is equal to a 60 not identicle. It has a crush sleave and c-clip axles. The bearings are different. Everything is different. DO not expect any Dana 60 parts to fit.
