F150 rear axle
#951304
03/15/11 05:03 PM
03/15/11 05:03 PM
Posts: 458 somewhere out there
Billy no mates
somewhere out there
Hi Guys,
I have the chance of buying a 9 3/4 out of a f150 with 373 gears & a locker. Would this axle be a Dana 60? other than spring perch location & width does anyone forsee any other problems I will have putting it in a early B body.
thanks Billy
BillyNoMates
Re: F150 rear axle
[Re: Billy no mates]
#951305
03/15/11 05:13 PM
03/15/11 05:13 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
F150 wouldn't have a 9.75... F250 & 350 from the 70's might... If it's a 83 or newer F150 it has a 8.8 which 3.73 & locker was common in...
Re: F150 rear axle
#951307
03/16/11 03:35 PM
03/16/11 03:35 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Many F150s from the late 90s and newer have Dana 60s in them. I worked at a Ford store for a while and thought about doing the same swap in the hot rod.
Re: F150 rear axle
[Re: feets]
#951308
03/16/11 03:58 PM
03/16/11 03:58 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Just because it has a 9 3/4 diameter ring gear does not make it a Dana 60. It is not. Did you read that article above? They are simply saying that they think it is equal to a 60 not identicle. It has a crush sleave and c-clip axles. The bearings are different. Everything is different. DO not expect any Dana 60 parts to fit.
