Re: superstock springs
[Re: phil4161972]
#951225
03/15/11 04:50 PM
03/15/11 04:50 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I am also changing my stock junked out springs but have read on here the super stock springs are crap? Any recomendations would be great.
67' charger 499 RB
10.57 at 127
[Re: BLONDE BARRACUDA]
#951227
03/15/11 05:09 PM
03/15/11 05:09 PM
dragram440
bigfork mn
I have just heard the new mexican ss springs were bad quality.
67' charger 499 RB
10.57 at 127
[Re: Dragula]
#951234
03/15/11 06:53 PM
03/15/11 06:53 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I have the "new" SS springs, from Mancini in Aug '08. I did have to add an extra leaf to the right side. The car felt like it was going to roll over on it's side when I launched. I had an old set of SS springs and used the 2 leaf from that set and added it between the main and 2nd leaf on the right side only. Problem solved. 11.5 tires, SS springs, non adjustable shocks (MP long, 50/50) NO pinion snubber and a Turbo Action "J" convertor, footbraking. Sitting still, the car sits up higher on RR, partly because of the extra leaf and partly because of the way I have the torsion bars set. But it leaves "square".
Brian Dunnigan
#951237
03/15/11 07:25 PM
03/15/11 07:25 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
no when he changed he went with the mano leaf spring
ok, that's cool. It seems that if there is enough hook with a particular system, any other system will be a poor return on the dollar. I personally made thousands of passes with SS springs. 11.50's, 1.55 60's. ALWAYS. When I went into the mid 10's, really inconsistent. Come to think of it, the car is still inconsistent, even with ladder bars.
[Re: Leigh]
#951238
03/16/11 10:12 AM
03/16/11 10:12 AM
dragram440
bigfork mn
Looks like I will be going with the ss springs. They seem to be the most affordable.
67' charger 499 RB
10.57 at 127
