Re: W9's on a 59 degree block with Fuel Injection
[Re: ADakotaRTGuy]
#951210
03/15/11 04:53 PM
03/15/11 04:53 PM
Posts: 17,868 S.E. Michigan
ZIPPY
S.E. Michigan
Injector bungs will need to be be pressed and welded into the manifold. The valley pan can either be fabricated with some sheet metal and a brake, or the off the shelf mp piece (which is often hard to find).
There is no thermostat housing since most racers don't use a thermostat. A manifold will need to be fabricated to incorporate a thermostat if you decide to use one....or lacking that, it might be cleaner to route all the water coming out of the heads right into the radiator.
Rich H.
Esse Quam Videri
[Re: Mr Hemi]
#951212
03/17/11 05:03 AM
03/17/11 05:03 AM
Posts: 6,145 Melbourne , Australia
LA360
There is a 59 degree version of a W9, would I use them, no, but it's not my car or money.
As Zippy said, it will require a water manifold if you are planning on using a thermostat. There are examples out there from various vendors that you can plumb 4 hoses into, most will make their own though.
I dare say Ryan will chime in with more detailed information, but an Indy head might get the job done and meet your requirements.
Alan Jones
[Re: LA360]
#951213
03/17/11 12:29 PM
03/17/11 12:29 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I'd buy a pint or two for a link to one of these vendors. I am puzzling over how to make my own and have some ideas , but welding aluminum isn't in my bag of tricks and if I have to pay for welding , I may as well pay for a purpose built unit. I can't find anything yet in my searches.
I have to add.........59 degree W-9's will out flow most other head choices for this application , so they aren't a bad choice necessarily. The extra head bolt bosses are typically shaved off from what I have seen. They have a notch cut on the side of the port for pushrod clearance that will restrict your ability to open up the intake port to a max flow job , but you should be able to get some very good numbers from them just the same. More than a well done W-2 I'd bet. With a better chamber , aluminum construction and more air flow , they look like a nice choice. You will spend more on rockers , headers and the rest of the supporting cast to make them work........this can be a draw back. Does the " cool and unique factor " tilt the scales in their favor ? For me , yes. But I'm going 48 degree.
[Re: tubtar]
#951214
03/17/11 12:47 PM
03/17/11 12:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I ended up making a couple of water manifolds for the heads(I never seen anything being sold out there) and I made a box with the cap to hook the manifold lines to.... all home made stuff
[Re: tubtar]
#951215
03/17/11 02:06 PM
03/17/11 02:06 PM
Posts: 1,019 Finland
mafo
Finland
it s not very hard to make one, a couple of hours in this one
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: ADakotaRTGuy]
#951217
03/17/11 09:40 PM
03/17/11 09:40 PM
tubtar
St. Paul , Mn.
Another issue I will hit is the front mount distributor. Not impossible , but it will have to be clever because I won't stand for unsightly. Ken , your would be the best approach..........but I also would like a thermostat. Not mandatory , but I am going to try and make it work.
[Re: ADakotaRTGuy]
#951222
08/13/12 09:23 PM
08/13/12 09:23 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Engine is already together, I updated it with my last post today.
lol my bad
