Re: welded diff
[Re: 572B1]
#950983
03/15/11 06:24 AM
03/15/11 06:24 AM
Posts: 4,647 aotearoa
rebel
aotearoa
i made my first locked diff by melting 3 pistons & pouring the molten ali into a 2 spider. man that was hard on the axle splines but it did work well. just made a plate that i held in place with some wire so the ali wouldn't run out the other side. no way the gears could ever move doing it like this.
Re: welded diff
[Re: 80arrow]
#950985
03/15/11 09:58 AM
03/15/11 09:58 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
We welded one in my buddies mud truck with a dana 60. You just need a few good size tacks in the spiders. Tack both sides and then rotate 180 degrees and tack it again. If you do to much it'll make the spiders brittle. He had a pretty stout 460 and a set of 43-45 inch tractor tires. It would break the axles before the gears. Maybe we just got lucky?
That's how we did it , but that was on dirt cars and they held up alright. Anywhere there is some hook could be an issue though.
Re: welded diff
[Re: tubtar]
#950986
03/15/11 12:05 PM
03/15/11 12:05 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I welded the spiders together in my last 9.25 in my 94 Ram 2wd. It had a mild 440 727 with a 9.5 4000 converter it ran 11.50's with a low 1.5 60fts launching it on a 150 shot and I ran it for 3 seasons and it still looks perfect. Its no longer in use!
67' charger 499 RB
10.57 at 127
Re: welded diff
[Re: FastmOp]
#950989
03/17/11 04:04 AM
03/17/11 04:04 AM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
My dad welded the spyder gears in the Ford 9" rear axle when I started racing the 1963 ford F-100 truck back in 2004. It was powered by a supercharged 350 Vette engine. Don't sweat we swapped it to a 1989 Dodge factory roller cam 360 back in 2008. It also has around 25,000 miles of daily driven summer use, including pulling various Mopars on our trailers all over the Midwest and Eastern U.S. Still works flawless to this day, however it does eat up the rear tires a little faster than an LSD would. Probably not as much as the burnouts and drag racing do though...lol
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: welded diff
[Re: 69B3GT]
#950992
03/17/11 06:59 PM
03/17/11 06:59 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
That is what I did to the 8 3/4 under my Demon.Welded the spider gears and never had any problems.Ran it that way for 7-8 yrs.Drove 25 miles to the track ran 6.90's to 7.0's on motor and 6.40's on a 100 shot never broke, just lucky I guess.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: welded diff
[Re: rebel]
#950995
03/18/11 12:04 AM
03/18/11 12:04 AM
Posts: 30,465 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
THIS is a good-one ... did you check piston-to-wall ?
