small block engine builder ? #950910
03/14/11 11:12 PM
03/14/11 11:12 PM
florida
hemifw Offline OP
hemifw  Offline OP
florida
Who builds the best small block to run 10.0s in a demon ? I figure 550 to 600 hp would be needed ?
71 Demon
Re: small block engine builder ? [Re: hemifw] #950911
03/14/11 11:16 PM
03/14/11 11:16 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
RyanJ/Shadydell Speed Shop.If he can make them run that slow
Re: small block engine builder ? [Re: B G Racing] #950912
03/14/11 11:54 PM
03/14/11 11:54 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
He's clearly forgotten more than I will ever know about these things.
I haven't used his machining skills yet , but I have gotten a hand full of parts and some great advice for my deal.
I wouldn't hesitate using him for a build if the opportunity presented itself.
Re: small block engine builder ? [Re: B G Racing] #950913
03/15/11 12:20 AM
03/15/11 12:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
he will take good care of you
Re: small block engine builder ? [Re: MR_P_BODY] #950914
03/15/11 12:53 AM
03/15/11 12:53 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: small block engine builder ? [Re: pittsburghracer] #950915
03/15/11 01:20 AM
03/15/11 01:20 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I appreciate the kind words. But there are lots of guys who can do same things I do...10.0's out of a SB these days is not that difficult in typical A body.
Depending on vehicle weight & efficiency you'll need to be in the low 600's HP wise to get there in a typical bracket setup. The car has alot to do with the ET. I've had 610 HP motors run in the 9.70's @ 3100 LBS & I've had 675 HP motors off same dyno run 9.80's @ 3200 LBS... you can figure out which chassis setup/coverter etc worked better. HP is'nt everything when it comes to building a quick car.
Re: small block engine builder ? [Re: RyanJ] #950916
03/15/11 02:23 AM
03/15/11 02:23 AM
florida
hemifw Offline OP
hemifw  Offline OP
florida
Thanks for the info, could you do it using a 360/380 hp magnum crate motor with the iron heads ?
71 Demon
Re: small block engine builder ? [Re: hemifw] #950917
03/15/11 02:35 AM
03/15/11 02:35 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Not with the pistons/rods that came in the Crate motor. You probably could for a few passes, but I would'nt build it with those parts.
Last crate motor I worked on had piston to valve clearance issues with a mild hyd roller. That was a 10.60 piece & that was about as far as I'd want to push a 380 crate.
There is a difference between guy in their garage going & taking 360 Crate & slamming some big heads on it & running fast for couple passes & a reputable shop that has to build the thing & make it live for 400+ passes etc & put their reputation on it surviving. Anything that comes through the door with stock rods or Eagle SIR's does not leave my hands without a rod upgrade. I just can't half ass stuff like that, it's not worth the job. But you'll get guys who will tell you, sure, throw a set of W2/5/INDY's on it & a big cam & you'll have a 10.0 piece... But I would'nt do it.
The only part I'd use from the 380 crate for a reliable 10.0 3100+ LB A body would be the 360 block.
Now if your car is 2500 LBS that is whole different story.
Re: small block engine builder ? [Re: RyanJ] #950918
03/15/11 02:59 AM
03/15/11 02:59 AM
florida
hemifw Offline OP
hemifw  Offline OP
florida
Thanks again, ill just sell the crate motor then. Will call you tomm on priceing for the build. thanks, fred
71 Demon
Re: small block engine builder ? [Re: RyanJ] #950919
03/15/11 09:36 PM
03/15/11 09:36 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Do not mean to hijack but how large of a cam did you put in the 380 hp crate motor before you ran into piston to valve clearance issues. I am thinking of buying ported Edelbrock heads and going larger with my cam on my 380 hp crate motor.It will be in my little D-50 that weights about 2950 with me in it,5.14 gears and 3500 converter. Has gone 7.46@91 mph so far in the 1/8. Thanks!
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: small block engine builder ? [Re: D-50] #950920
03/15/11 10:25 PM
03/15/11 10:25 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Do not mean to hijack but how large of a cam did you put in the 380 hp crate motor before you ran into piston to valve clearance issues. I am thinking of buying ported Edelbrock heads and going larger with my cam on my 380 hp crate motor.It will be in my little D-50 that weights about 2950 with me in it,5.14 gears and 3500 converter. Has gone [Email]7.46@91[/Email] mph so far in the 1/8. Thanks!
I'll have to dig up the cam card, it was'nt "huge". High 240's/low 250's @ .050" 108 LSA & high .500's low .600's lift if I recall correctly. Made good power, but was real tight on piston to valve.
Re: small block engine builder ? [Re: RyanJ] #950921
03/15/11 11:39 PM
03/15/11 11:39 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Thanks for the info Ryan! I hope to get my D-50 in the 6.90's with the head and cam swap.
