Gear Ratio #950818
03/14/11 08:58 PM
03/14/11 08:58 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Is there a way to determine the gear ratio in the rearend?
Grandma always said I had "hands of gold"!
Re: Gear Ratio [Re: CHRGR69] #950819
03/14/11 09:07 PM
03/14/11 09:07 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You can get a rough idea.Jack up the rear wheels.Put in netural.Mark D shaft and one wheel stud.Turn wheel one compete revolution and count the number of turns the drive shaft turne.If the wheel makes 1 turn and the shaft say makes 4 turns the ratio is about 4.00.Rocky
Chrysler Firepower
Re: Gear Ratio [Re: CHRGR69] #950820
03/14/11 09:14 PM
03/14/11 09:14 PM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
If it is a sure grip,jack it up and position the yoke straight up and mark it with a piece of tape.Then place a piece of tape on the face of the tire at the bottom and one on the floor that lines up with the one on the tire.Have someone slowly rotate the tire while you count the number of rotations of the yoke.If the yoke rotates 3 1/2 times it is a 3.55, 3 3/4 times it is a 3.73 and so on.
Re: Gear Ratio [Re: 68GTS383] #950821
03/14/11 09:48 PM
03/14/11 09:48 PM
Northern Virginia
Moparmaniacc Offline
Northern Virginia
What if he just counts his rpms in Drive or 4th gear...how many MPH for 3000 RPM, etc. Use a GPS receiver for accuracy.
I am interested in this myself, I am supposed to have a 3.23 and it sure feels like a 3.55 or higher to me.
Re: Gear Ratio [Re: CHRGR69] #950822
03/14/11 10:09 PM
03/14/11 10:09 PM
If a sure grip jack both wheels just off the ground, put in neutral, turn till valve stem is at 6 o'clock, then rotate till stem is back at 6 o'clock & 3&1/2 turns on the ujoint is 3:55. If single track, jack up 1 wheel just off the ground & turn the tire 2 revolutions & count the ujoint turns same as above
