Gear Ratio
#950818
03/14/11 08:58 PM
03/14/11 08:58 PM
Posts: 1,534 Florida
CHRGR69
Is there a way to determine the gear ratio in the rearend?
Grandma always said I had "hands of gold"!
Re: Gear Ratio
[Re: CHRGR69]
#950819
03/14/11 09:07 PM
03/14/11 09:07 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
You can get a rough idea.Jack up the rear wheels.Put in netural.Mark D shaft and one wheel stud.Turn wheel one compete revolution and count the number of turns the drive shaft turne.If the wheel makes 1 turn and the shaft say makes 4 turns the ratio is about 4.00.Rocky
Chrysler Firepower
Re: Gear Ratio
[Re: CHRGR69]
#950822
03/14/11 10:09 PM
03/14/11 10:09 PM
RapidRobert
If a sure grip jack both wheels just off the ground, put in neutral, turn till valve stem is at 6 o'clock, then rotate till stem is back at 6 o'clock & 3&1/2 turns on the ujoint is 3:55. If single track, jack up 1 wheel just off the ground & turn the tire 2 revolutions & count the ujoint turns same as above
