Re: FBS to B-1 intake comparison
[Re: HardcoreB]
#950616
03/14/11 11:03 PM
03/14/11 11:03 PM
Posts: 235 Tucson AZ.
RADAMX
Tucson AZ.
Thanks for the pic. Is the intake-to-head mating angle the same? BTW what's with the small pushrods?
Ok yes the angle is the same as a matter of fact I just set a 400 low deck B1 intake on it . and it fit rather well,maybe to well. ..
The pushrods are 3/8 I don't think They need to be any bigger?
[Re: RADAMX]
#950617
03/15/11 08:00 AM
03/15/11 08:00 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The pushrods are 3/8 I don't think They need to be any bigger? [/quote Depends on the cam. Most high end motors will use something bigger. The longer the pushrod, the bigger it has to be. The same goes for valve train weight, rate of lift, spring used, etc.
