Soon the hemi and 65 b-body will meet #950480
03/14/11 10:09 AM
03/14/11 10:09 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Hi,
Should I'll be worried about this swap, 426 Hemi in a 65 b-body.
What I have:
-Inverted passenger shock tower
-V8 K-member
-Schumascher Hemi engine swap motor mounts
-TTI 62-65 b-body hemi 2 1/8" headers
-Milodon Oilpan 31010
-Flexible engine oil-stick and trans oil-stick
-65 crossram magnesium intake/dual hollys with velocity stacks
-Reinforcement in hood cut with the oval hole in the hood (adapter plate)
-Later 66 and up 727 with schumascher trans swap mount 62-65 trans member (drive shaft and everything is in order/correct lenght)
-Manual valve body
-TTi 3" H-pipe exhaust
-Subframe connectors and stronger trans/rear axel/suspension
Could I get any problem installing the hemi?
Cheers!
1964 Dodge 330 Max Wedge clone
1965 Dodge Hemi A990 clone
Re: Soon the hemi and 65 b-body will meet [Re: Snoddas] #950481
03/14/11 10:40 PM
03/14/11 10:40 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Never use this brake master cylinder if you drive it!
Re: Soon the hemi and 65 b-body will meet [Re: earlybee] #950482
03/15/11 03:23 AM
03/15/11 03:23 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
I understand, the reason for that I assume is the one line braking system?
Re: Soon the hemi and 65 b-body will meet [Re: Snoddas] #950483
03/17/11 08:17 PM
03/17/11 08:17 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
Hope i'm not jinxing my self here, but I drive my 64 all the time with that setup and it works pretty well for what it is. Everything is new in my system.
If it's in proper order it will do ok.
Didn't see anything about your radiator... what are you running?
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: Soon the hemi and 65 b-body will meet [Re: HitIt] #950484
03/18/11 03:44 AM
03/18/11 03:44 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Thanks for the response. I probably forgot to mention all sort of stuff like the 8-bolt flexplate and more and more anyway...
I run an old OEM radiator (correct inlet and outlet) its redone and have 3 rows.
Did you invert or make and work on the shock tower?
