Installing head bolts
#950202
03/13/11 09:00 PM
03/13/11 09:00 PM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
'70 383.
Head bolts have blind holes if I remember correctly, so no teflon on the threads, correct?
Do you prefer dry or with oil to torque them down?
Re: Installing head bolts
[Re: VITC_GTX]
#950203
03/13/11 09:15 PM
03/13/11 09:15 PM
RapidRobert
I dip the threads in 30 wt eng oil then blow em off w shop air EDIT I would chase the threads w "thread chasing" taps which are different from a regular tap/die set. they dont dig into the threads as much & a set of em (taps) is cheap
