Oil pump core plug replacement #950065
03/13/11 06:24 PM
03/13/11 06:24 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey guys,
Went to take apart my brand new Meiling Oil pump to install a HP releif spring in it and found there was a core plug behind the cotter pin. I ended up drilling a hole in the plug to pull it out so i could change the spring. Now im wondering, can i reuse this plug even though it has a hole in it? or will I have to replace it with another plug? I still have the old oil pump in a box somewhere, was thinking maybe i can figure out how to get the plug outta that one if its the same
Any suggestions or ideas of what to do?
thanks!
Matthew
Re: Oil pump core plug replacement [Re: mshred] #950066
03/13/11 07:56 PM
03/13/11 07:56 PM
Not sure if it has psi against the back side but I think so & yes I'd get another one. Your parts house will have one, just get a deep one like a good ole Dorman. If they dont have the correct dia, MP has it but it'll for sure b more & will have the HP spring P3690944 along w it
Re: Oil pump core plug replacement [Re: RapidRobert] #950067
03/15/11 03:26 PM
03/15/11 03:26 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
will do thanks!
