I can use this 318 Balancer on a 340..right?
#950048
03/13/11 06:17 PM
03/13/11 06:17 PM
Posts: 4,518 Indiana
MonGoo$e
Indiana
The balancer I have off of the '70 340 I'm rebuilding isn't broken, just well work, the rubber thats exposed on the backside is cracked and dryrotted. the tin hub was cocked a little and I was able to straighten it back down..
But I have a '74 318 balancer that is near identical except for some numbers, and the position of the timing mark.
If I relocated the timing mark, am I good to go? the rubber in it looks like new.
I clocked both of them the same and marked where the timing mark shows up
Re: I can use this 318 Balancer on a 340..right?
[Re: MonGoo$e]
#950049
03/13/11 06:17 PM
03/13/11 06:17 PM
MonGoo$e
Indiana
[Re: MonGoo$e]
#950050
03/13/11 06:38 PM
03/13/11 06:38 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Run it... Balance will be ok, I think the one pulley bolt hole was offset on the 74 but not the 70...
[Re: 340SHORTY]
#950053
03/13/11 10:00 PM
03/13/11 10:00 PM
RapidRobert
I'm assuming the shallow balancing holes are just to bring each particular balancer to neutral
[Re: 340SHORTY]
#950054
03/13/11 11:29 PM
03/13/11 11:29 PM
MonGoo$e
Indiana
what are those ink marks on the outer ring for ??
well, like i said, i marked them to show where the balancing marks are, since you can't see the outer edge in the pics.
