I've Got A Bit Of A Dilemma #950007
03/13/11 05:44 PM
03/13/11 05:44 PM
MR_P_BODY Offline OP
With my steering on my Rampage... with the engine in
where I have it and the steering rack just clearing
the crank pulley the rod ends will have a big angle...
not a big deal on a drag car but on a street car the
two wheels turn at a different rate in a corner... I
still need to put the proper wheel and tire on it to
see if I can make a longer steering arm... which will
help with slowing the steering rate and the turn radius...
I can move the engine back 1" more which will help...
I know how to get around this problem BUT it would
look BAD... I can cut the tie rods and set them parallel
them then weld a spacer in between.... but damn that
would look UGLY and I'm sure people would say...
what the heck did you do that for..... DAMN I dont
know what to do..... gotta think
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950008
03/13/11 06:18 PM
03/13/11 06:18 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Just set the engine back even more the csr will like it
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950009
03/13/11 06:18 PM
03/13/11 06:18 PM
Well its not as bad as I figured but I will have to
move the engine back that 1 1/4" that I have... I put
the wheel on the spindle that I will run but I dont
have the tires yet... but looking at the steering arm
I can make them longer and should just clear the tire...
I gotta get the tires before I can make sure... but
things are looking better
Re: I've Got A Bit Of A Dilemma [Re: emarine01] #950010
03/13/11 06:23 PM
03/13/11 06:23 PM
I'm gonna move it back 1 1/4" but I wont go any farther,
I want to have 19" from the front of the seat to the
firewall... and the seat cant go back any more
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950011
03/13/11 08:42 PM
03/13/11 08:42 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
... I know how to get around this problem BUT it would
Could you put one of those flexible shock boots over it? The kind that come w/ off-road (and maybe others) shocks. Different colors and are very inexpensive. If they are long enough, just go from the rack out to the tie rod.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950012
03/13/11 08:47 PM
03/13/11 08:47 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
The thing is gutted now, just make it an extended cab Rampage...
Re: I've Got A Bit Of A Dilemma [Re: RodStRace] #950013
03/13/11 08:56 PM
03/13/11 08:56 PM
I wouldnt change the cab... but I did give it some
thought about cutting the fenders and moving the front
wheels forward
If I do have to cut the tie rods I like the idea
of putting a boot over it... no one would know
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950014
03/13/11 09:03 PM
03/13/11 09:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I like the idea of moving the front wheels forward; it'd look better aesthetically, and give you some room.
Re: I've Got A Bit Of A Dilemma [Re: topside] #950015
03/13/11 09:09 PM
03/13/11 09:09 PM
I'd really like to keep it stock looking but if I need
to move them I will
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950016
03/13/11 09:21 PM
03/13/11 09:21 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
looks different!!!
Re: I've Got A Bit Of A Dilemma [Re: RodStRace] #950017
03/13/11 09:26 PM
03/13/11 09:26 PM
That looks WAY different with the tire up that much
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950018
03/13/11 10:30 PM
03/13/11 10:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yikes! I was thinking just a couple inches, centering the wheel/tire in the fender. Might be able to just move the front of the opening, depending on OD of the tire you run, and most people would likely not even notice, but the proportions would be better than the long stock overhang.
Re: I've Got A Bit Of A Dilemma [Re: topside] #950019
03/13/11 11:23 PM
03/13/11 11:23 PM
I dont think I'll have to move the tire forward IF
I move the engine back the 1 1/4", make longer steering
arms(which it could use anyways) and cutting the
tie rod and putting a cover over it(I might not need
to cut the tie rod ... I leave that as my last choice)...
after I pick up my new hood tomorrow I'll take some
measurements
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950020
03/14/11 04:40 AM
03/14/11 04:40 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
You can usually angle the rods 3" from the steering centerline
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950021
03/14/11 07:03 AM
03/14/11 07:03 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I look at it this way...
As long as you have a legitimate answer for the "what the heck did you do that for", there was no alternative, and it's a sound way of doing it, don't worry about it. If you can live with it and it works, it is what it is. Custom building...fun stuff!
With custom stuff, there are no rules. You make them up as you go along.
Re: I've Got A Bit Of A Dilemma [Re: B G Racing] #950022
03/14/11 10:21 AM
03/14/11 10:21 AM
I never heard that Bob... I'm sure that we would all
love to have that angle from the steering arm to the
rack at 90* and the farther off that angle it hurts
more... plus the distance between the rack and the
steering arm makes a big difference when you say that
3" number(10" vs 20") would more than double the
angle with the 3" stager
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950023
03/14/11 12:48 PM
03/14/11 12:48 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I know you weren't planning on stuffing the wheels that far forward, you said you only needed a couple inches. That would hardly even show. Figured I'd go extreme so you could see the change on a bitty picture. It sure changes the look!
Probably the easiest would be extending the rear of the front fender, moving the whole thing forward. Doing just the wheelwell is more work, and the pic shows how the proportions change.
Re: I've Got A Bit Of A Dilemma [Re: RodStRace] #950024
03/14/11 02:03 PM
03/14/11 02:03 PM
I have my wheels out right now having the tires mounted
so when I get them back I can see a bit better on
the steering arm clearance... that will determine
what I need to do
Re: I've Got A Bit Of A Dilemma [Re: MR_P_BODY] #950025
03/14/11 02:12 PM
03/14/11 02:12 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
fLAMING RIVER makes different length racks. In my case I needed a longer one for my Roda Runner that the Pinto unit that was in it.As for making longer tie rod can't you use a Heim end to replace
what you have now and make that longer by using a fresh piece of tubing threaded to accept the Heim?
home of the
Sox and Martin Hemi Duster
Re: I've Got A Bit Of A Dilemma [Re: HEMIFRED] #950026
03/14/11 02:25 PM
03/14/11 02:25 PM
Its not the length of the rack its the location of
it fore and aft in the car... I'd like to move it
rearward in my chassis so the end of the steering arm
is straight across from the rack centerline... once
I get my wheels and tires back I set it up and take
a pic
