Re: 68 4 speed in a 71 B body crossmember?
[Re: DANA60]
#949994
03/13/11 07:41 PM
03/13/11 07:41 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I was thinking that a 71 B body took the E body shifter location. Does the 68 model trany have both shifter locations? Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#949996
03/13/11 07:45 PM
03/13/11 07:45 PM
Posts: 3,095 Idaho
Runner
Idaho
nope that started in 70, i believe (dont know for sure) that the 71 bench seat b bodies used the forward mount like the earlier cars.
[Re: Russ_Davis]
#949997
03/13/11 08:58 PM
03/13/11 08:58 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Will this work with the original or does it need to be modified?
Unless you can bolt a 66-69 crossmember in you are going to have to modify the crossmember , the mount location is in a different place , right in the middle of the crossmember. I do not know if there is a crossmember for a B/E body that is not a spool mount ?
[Re: Russ_Davis]
#949999
03/13/11 10:27 PM
03/13/11 10:27 PM
Posts: 5,268 NY
70440+6bbl
NY
You sure can and IMO, it would be the best solution.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: 70440+6bbl]
#950000
03/14/11 09:53 AM
03/14/11 09:53 AM
JohnRR
U.S.S.A.
, if you can find a truck OD trans that will be a cheap source , just be warned that it will have a 308 bearing , use that bearing instead of trying to transfer the one currently on the mainshaft.
