273 cam? #949986
03/13/11 05:13 PM
03/13/11 05:13 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
1967 stock 2 barrel 273? Anyone know what cam i can use to get a good sound out of the exhaust. It is a solid cam now. I will change the intake to a 4-barrel also. Thanks
Re: 273 cam? [Re: bobs69] #949987
03/13/11 09:39 PM
03/13/11 09:39 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Anybody??
Re: 273 cam? [Re: bobs69] #949988
03/13/11 10:01 PM
03/13/11 10:01 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
You want another solid in it or switch it to a hydraulic stick? 67' 273, probably around 9 to 1 cr. 68'-73' 340 automatic trans cam and springs is good with
(if it can be found) a 273/235 hp 4bbl intake with a
500-625cfm Carter AFB OR 318 4bbl intake manifold with a 600 cfm Holley.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 273 cam? [Re: HYPER8oSoNic] #949989
03/14/11 01:23 AM
03/14/11 01:23 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Look at the ISKY cat. Isky E4 grind. pretty much the sock replacement for the 235hp cam. Good overall cam. That 273 will like a lot of gear.
Re: 273 cam? [Re: dart4forte] #949990
03/14/11 11:39 AM
03/14/11 11:39 AM
scratchnfotraction Offline
the stock 273 hipo solid cam is nice,used it in a couple 318s also
have had a hipo cam in a 273 with .500 lift..it was nasty for a 273
on the isky cam as well
Re: 273 cam? [Re: scratchnfotraction] #949991
03/14/11 10:58 PM
03/14/11 10:58 PM
Desert Tracker
Desert Tracker
As far as gear is concerned, anything OVER 3.91-1
is good. Also had a 235hp 273 Cuda that couldn't keep a set of tires on it for no more than a year! Fun car!!
