Re: 4,5 bore HEMI + 4,375 crank: which length rods?
[Re: domingo]
#949894
03/13/11 03:00 PM
03/13/11 03:00 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
7.1 or longer ![](/ubbthreads/images/graemlins/Twocents.gif) What size are the crankshaft rod journals? If BB Chevy there are a lot of choices on brand, style and materailas for us Mopr engine lovers ![](/ubbthreads/images/graemlins/scope.gif) The longer the rod the lighter weight the pistons will be, the lighter the piston the better the motor will rev up, and slow down ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: domingo]
#949897
03/13/11 04:51 PM
03/13/11 04:51 PM
Posts: 126 Nevada
theman440
Nevada
[Re: theman440]
#949898
03/13/11 05:25 PM
03/13/11 05:25 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
not mentioned here is that wriist pin location and comp height will determine what the right rod to match should be. Off the shelf pistons will be made for a matching length rod. I would see what piston might work without being custom made. 7.100 is the most common otherwise you might wind up with the wrong combination
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#949899
03/13/11 05:46 PM
03/13/11 05:46 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Yep. My question was more along these lines...
I will check what rod journals do I have...
