2011 Ram rear diff question #949708
03/13/11 02:36 AM
03/13/11 02:36 AM
70duster340 Offline OP
Does the anti-spin only come with the 3.92 gears? I was looking at some Rams today, and from what I could see, most were equipped with 3.55's. No mention of anti-spin on the 3.55 equipped trucks.
Anybody advise me on this?
TIA!
Re: 2011 Ram rear diff question [Re: 70duster340] #949709
03/13/11 04:11 AM
03/13/11 04:11 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I dont know why they would limit themselves to the 3.92 ratio. My 2007 has a 3.55 with the Anti Spin diff. Its a 2wd too.
Re: 2011 Ram rear diff question [Re: 70duster340] #949710
03/13/11 10:16 AM
03/13/11 10:16 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
Hmmm....a buddy of mine also has a 2011 hemi ram with 3.55s and its a open rear too. It does have 4 wheel drive though.
Re: 2011 Ram rear diff question [Re: POZEST] #949711
03/13/11 11:31 AM
03/13/11 11:31 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
I just ordered a truck with 392 gears. They just changed the way they sell it. Now it was a 75 dollar option and you only get the upgrade from 355's. Before that they used to charge $500 and you also automatically got the antispin.
Re: 2011 Ram rear diff question [Re: gygeneral] #949712
03/13/11 12:08 PM
03/13/11 12:08 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
Wonder if they fixed the anti-spin 9.25 break off and destroy clip problem yet??
Re: 2011 Ram rear diff question [Re: POZEST] #949713
03/13/11 12:19 PM
03/13/11 12:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It makes no sense to me to buy a 4wd with an open rear.
Don't be the exception.
Re: 2011 Ram rear diff question [Re: Supercuda] #949714
03/13/11 12:25 PM
03/13/11 12:25 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It gives you alot more traction with both ends of vehicle pulling for ya basically.
Re: 2011 Ram rear diff question [Re: buildanother] #949715
03/13/11 12:58 PM
03/13/11 12:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What?
I am not talking about 4wd vs 2wd, I am saying if you are going to spring for a 4wd system and cheap out by getting an open rear you've payed for 3wd instead.
Re: 2011 Ram rear diff question [Re: Supercuda] #949716
03/13/11 01:06 PM
03/13/11 01:06 PM
chicagoland,usa
chicagoland,usa
Well, up in snow belt, you are safer with front and rear open diffs, than a good limited slip in rear which can quickly kick the rear sideways on you, and I'm NOT referring to off pavement driving where you need as many wheels driving as possible, that's all.
Re: 2011 Ram rear diff question [Re: Kern Dog] #949717
03/13/11 01:34 PM
03/13/11 01:34 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
How do you know if your truck has the anti spin diff ? I have a 2007 4X4 with 3.92's. If I get into the throttle hard both wheels hook up. But on the jack stands when one wheel spins foreward, the other one spins backwards. What is the code on the build sheet for the anti spin diff ? I'm not sure of the changes thay have made in these modern trucks. My last truck was a 97 Ram with open rear end.
Re: 2011 Ram rear diff question [Re: buildanother] #949718
03/13/11 01:59 PM
03/13/11 01:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, now that makes a bit of sense. However, I disagree that an LSD is an issue even up north. Firstly, if you need 4wd in order to drive in the snow, then what you really need is driving lessons. Next, if you can't keep your rear from kicking out with an LSD and slippery pavement, see number one. Finally, with open diffs front and rear why even bother paying the costs of 4wd? While I may now live in West Texas, I grew up and learned to drive in the north where snow was plentiful, driving used muscle cars with zero traction control other than your brain and foot. No chains, no snow tires. Just a shovel, some sand and a couple of expanded metal pieces in the trunk to extricate myself if I got stuck. All it took was once and never again.
Heck even today when I go mudding I only use 2wd, so I can shift into 4wd if I get stuck, hasn't happened yet but it's there is I need it.
Re: 2011 Ram rear diff question [Re: Supercuda] #949719
03/13/11 02:20 PM
03/13/11 02:20 PM
chicagoland,usa
chicagoland,usa
Whatever.
Re: 2011 Ram rear diff question [Re: Supercuda] #949720
03/13/11 03:35 PM
03/13/11 03:35 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You are to funny. Come on up to upper michigan with your 2wd driving skills. I will humble you in seconds.
Re: 2011 Ram rear diff question [Re: NITROUSN] #949721
03/13/11 03:51 PM
03/13/11 03:51 PM
Under My Car
Mopar_Country Offline
Under My Car
I have been driving for close to 40 years and lived in the north all of my life so I think I know how to drive in snow. I own 3 4WD trucks and depending on HOW much snow there is I use it. In my new Hemi Ram and my older Ram the front is much heavier than the rear so it is quite difficult to move around without using it. NOW if I put a pallet of salt in the back which weighs 2450 LBS then yes I can drive in 2 wheel, because we have now shifted the weight to the rear.
I would love to see you drive in 6 inches of snow on the road with no weight in the back. Lessons please.
Re: 2011 Ram rear diff question [Re: Mopar_Country] #949722
03/13/11 04:05 PM
03/13/11 04:05 PM
Folks, I surely didn't mean to start something here. I just wanted to know if, in fact, it's true that only the 3.92-geared diffs in the new Rams come with anti-spin. Can anti-spin be had with other ratios???
Re: 2011 Ram rear diff question [Re: NITROUSN] #949723
03/13/11 04:32 PM
03/13/11 04:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Guess you totally missed the part about me growing up in the north.
But hey it wouldn't fit your preconceived notions would it? Just last month we had an ice storm roll in, started out a hard rain and then it froze. 2 inches of ICE, not panty waist snow, on the roads. You know what I did?
I stayed home.
Nobody was going anywhere.
Not even clowns in 4wd's, except into the ditch that is. Even my fancy traction control stayed home that day, lol.
Re: 2011 Ram rear diff question [Re: 70duster340] #949724
03/13/11 04:37 PM
03/13/11 04:37 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
My son has a 2010 with the 3.55 rear, he was told the anti-spin is only available with the 3.92 rear.
Re: 2011 Ram rear diff question [Re: krw71ragtop] #949725
03/13/11 08:25 PM
03/13/11 08:25 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I have the widow sticker from when i bought it new. I've changed the fluid and checked the unit as well. No problems with it yet.
This truck was loaded up with almost every option available for an SLT 2wd. I'm glad that it had the Anti Spin though.
Re: 2011 Ram rear diff question [Re: Kern Dog] #949726
03/13/11 11:47 PM
03/13/11 11:47 PM
I guess I don't understand why the anti-spin can only be offered with the 3.92's. But, I ain't no bean counter, so I guess I'll never know the answer to that question. I had a 2002 Dakota with the 4.7L and 3.55's with an anti-spin axle. I guess things have changed over the years?
Re: 2011 Ram rear diff question [Re: Supercuda] #949727
03/13/11 11:52 PM
03/13/11 11:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I stayed home.
Again you crack me up. You are funny dude. Ice and snow is a norm here. I never missed a day of work due to ice and snow. A pure panty waist stays home.
My preconceived notions are right on.
