shifter grease? #949671
03/13/11 12:35 AM
03/13/11 12:35 AM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
I'm rebuilding a 3spd shifter is there a special grease? Does anybody know if there are parts available for a 3spd shifter. I'm looking for the shift plates between the levers. Brewers carries 4spd stuff and if it crosses over to a three spd your lucky but does not stock ant 3spd specific stuff.
Re: shifter grease? [Re: 340swing] #949672
03/13/11 08:39 AM
03/13/11 08:39 AM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Do you use wheel bearing grease or is it something different?
Re: shifter grease? [Re: 340swing] #949673
03/13/11 09:28 AM
03/13/11 09:28 AM
IN
ahy Offline
ahy  Offline
IN
I used wheel bearing grease on 5 speed shifter parts because its heavy enough to stay put and at least help reduce vibration. I don't know on the shifter parts. Its a bit of a long shot but may be worth checking a dealer.
Re: shifter grease? [Re: 340swing] #949674
03/13/11 05:28 PM
03/13/11 05:28 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I've pulled apart a couple of new Hurst mechanisms and they had a nasty black grease that looked to be molybdenum disulfide. That's what I used to assemble them, MIL-G-21164 moly grease.
Re: shifter grease? [Re: 340swing] #949675
03/13/11 06:42 PM
03/13/11 06:42 PM
Kirkland, Washington
Pacnorthcuda Offline
I just used wheel bearing grease, Mobil 1 synthetic.
Couldn't believe all the crap in there!!! Sand, rocks unbeleivable.
Re: shifter grease? [Re: Pacnorthcuda] #949676
03/13/11 08:47 PM
03/13/11 08:47 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Thanks guys i found the same thing 40 years and all kinds of crud in the old grease.
Re: shifter grease? [Re: 340swing] #949677
03/13/11 11:13 PM
03/13/11 11:13 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Front
Re: shifter grease? [Re: pacifica] #949678
03/13/11 11:14 PM
03/13/11 11:14 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
back
Re: shifter grease? [Re: pacifica] #949679
03/14/11 04:46 PM
03/14/11 04:46 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Correct or not, I've used red wheel bearing grease and never had a problem.
Re: shifter grease? [Re: rabid scott] #949680
03/14/11 09:30 PM
03/14/11 09:30 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
pacifica, what does the grease look like in the tube? Does it look like lithium grease,wheel bearing or moli-grease. Does it say what it is on the tube?
Re: shifter grease? [Re: 340swing] #949681
03/14/11 11:29 PM
03/14/11 11:29 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
The tube does not list "ingredients". Here is a pic of what is inside. Looks like what John described in above post. I think any of the lubes mentioned above will work fine.
I only posted the pic cause I got this stuff many years ago when I sent my shifter in to get rebuilt. At the time for $15.00, you could send your "Hurst shifter" back to Hurst and they would make it like new and ship it back. They included this tube with my shifter
Re: shifter grease? [Re: pacifica] #949682
03/14/11 11:31 PM
03/14/11 11:31 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
tube contents
Re: shifter grease? [Re: pacifica] #949683
03/15/11 07:31 AM
03/15/11 07:31 AM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Thanks for the picture. I'm sure all of the above will work fine. I was trying to see if there was a specific shifter grease. I will try to find some now that I know.
Re: shifter grease? [Re: 340swing] #949684
03/15/11 11:33 AM
03/15/11 11:33 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
My 1968 SM states lubricate with light engine oil FWIW. grease picks up to much grit if you drive a lot
