synchronizer cones A833 #949591
03/12/11 11:07 PM
03/12/11 11:07 PM
NJ
440challenger Offline OP
NJ
I am in the process of rebuilding my a833. I just put all new bearings and syncros in. I just read somehwere that you shoudl sand the synchronizer cones with 120 grit sandpaper. Should i do this? i dont mind taking it apart again if its important. What exactly is the synchronizer cone,which needs to be sanded?
Re: synchronizer cones A833 [Re: 440challenger] #949592
03/13/11 11:08 AM
03/13/11 11:08 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I wouldn't worry about it. I didn't do it on mine and it works fine. The cones are the female part that go up against the gear face (which is a male cone)
Re: synchronizer cones A833 [Re: 440challenger] #949593
03/13/11 12:27 PM
03/13/11 12:27 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Actually you want to sand the male surface (the gear side of the cone ) so that the brass syncro ring grabs it to aid shifting. You do not sand the brass stop rings if new.
Re: synchronizer cones A833 [Re: torkrules] #949594
03/13/11 02:02 PM
03/13/11 02:02 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I think you got that backward. The part you sand in the male cone on the gear. I've done this twice with 220 grit wet-or-dry and it seemed to work. The problem is I don't know of anyone who didn't do it, tried the transmission out, then removed the tranny, sanded the cones, reassembled, and tried it again.
Re: synchronizer cones A833 [Re: 6PakBee] #949595
03/13/11 02:49 PM
03/13/11 02:49 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
The reason for those "cones" is to create a friction that slows the synchros so that they can blend with the slotted collar that the shift fork is pushing.
Once that surface is glazed/smooth it isn't as effective as something that has a cut surface.
The synchro/brass ring/blocking ring inside surface is knurled for this same reason. It's not the teeth that slow the gears to provide a shift. That's called clatter.
Re: synchronizer cones A833 [Re: 6PakBee] #949596
03/13/11 05:05 PM
03/13/11 05:05 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Didn't say you had to sand anything. Just pointed out what the cones are.
Re: synchronizer cones A833 [Re: torkrules] #949597
03/13/11 05:59 PM
03/13/11 05:59 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I dunno. The OP stated he read you should sand the synchronizer cones. That is the conical section of the gear. I have never heard the synchronizer rings referred to as anything other than 'rings' or 'blocker rings'. No big deal one way or the other.
Re: synchronizer cones A833 [Re: 440challenger] #949598
03/13/11 08:31 PM
03/13/11 08:31 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I thought I had every piece of literature that existed for 833 trannys and I've never seen that. Anyhow, personally I think with the lube in there the slightly scuffed surface wouldn't make the least bit of difference.
Re: synchronizer cones A833 [Re: Stanton] #949599
03/13/11 09:47 PM
03/13/11 09:47 PM
NJ
NJ
i read it in the mopar muscle a833 rebuild they did. jamie passon?? did the work. I got the trans back in and it shifts so were all good!
