What's better at 8000RPM 6 rib serpentine or V belt ? #949414
03/12/11 07:17 PM
03/12/11 07:17 PM
Ridley Park, Pa.
69MOPE Offline OP
super gas
69MOPE  Offline OP
super gas
Ridley Park, Pa.
I know the 6 rib has more surface area but will it stay on at high RPM?
Re: What's better at 8000RPM 6 rib serpentine or V belt ? [Re: 69MOPE] #949415
03/12/11 07:19 PM
03/12/11 07:19 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
I have the march serpentine kit on my engine and ran it to 8000 rpm quite a bit.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: What's better at 8000RPM 6 rib serpentine or V belt ? [Re: W5Duster436] #949416
03/12/11 07:46 PM
03/12/11 07:46 PM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
A serpentine belt if aligned properly will stay on better, last longer and it takes less hp to turn. Thats why the oe's went to them
Re: What's better at 8000RPM 6 rib serpentine or V belt ? [Re: tvt59] #949417
03/12/11 08:30 PM
03/12/11 08:30 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Check out the light weight V-belts the circle track guys are using. I think they can run a smaller radius (less pulley weight) and 1/2 the size of a old school V-belt. they look almost plastic.
