Are the start part number stamped into the body near the back of the motor?
If so, do the part numbers below have a specific application?
2099157 date code 224
2091979 date code 388
4111860 date code 344
I tried searching, here and the web but came up empty.
I assume that a 1965 date coded starter and a 1975 date coded starter would have differnet part numbers?
