Ignition switch diagram #949246
03/12/11 03:05 PM
03/12/11 03:05 PM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
Need a diagram for a 68 Coronet R/T ignition switch is there one under the tech archives somewhere
Re: Ignition switch diagram [Re: KY Charger] #949247
03/12/11 03:17 PM
03/12/11 03:17 PM
could check the wiring diagrams at www.mymopar.com but I think red is hot in, black is acc, solid blue is ign1, yellow is start, brown is ign2 (ballast bypass) and blue w (white iirc) tracer is iirc connected to the same terminal as the solid blue & dont remem where it goes out to
Re: Ignition switch diagram [Re: RapidRobert] #949248
03/12/11 09:21 PM
03/12/11 09:21 PM
Bowling Green, KY
K
K
Bowling Green, KY
OK thanks!
