Vacuum Pump #949238
03/12/11 02:18 PM
03/12/11 02:18 PM
usa
9
90ram Offline OP
90ram  Offline OP
usa
I'm building a 572 Engine with B-1 Heads,It has a Dual line oil system.
Not a Dry sump. Can I run a Vacuum Pump? Should I run a Vacuum pump. Or is a Vacuum Pump a Bad Idea with out a Dry Sump
Re: Vacuum Pump [Re: 90ram] #949239
03/12/11 02:31 PM
03/12/11 02:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can and most likely should run a vac pump
Re: Vacuum Pump [Re: 90ram] #949240
03/12/11 02:32 PM
03/12/11 02:32 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Many people use a vacuum pump with a wet sump.
[edit] I just got treed by MrP.
Re: Vacuum Pump [Re: GomangoCuda] #949241
03/12/11 03:11 PM
03/12/11 03:11 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
A vac pump increases ring seal and removes moisture among other things and can add an easy 25hp, why wouldn't you
Re: Vacuum Pump [Re: MegaDart] #949242
03/12/11 05:29 PM
03/12/11 05:29 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
See my post here
Re: Vacuum Pump [Re: 90ram] #949243
03/12/11 08:41 PM
03/12/11 08:41 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
I would run a moroso three vane pump and if the engine is sealed up good it should have about 15 inches. We have used a lot of them and thats what we end up with.
Re: Vacuum Pump [Re: PETE@BESTMACHINE] #949244
03/12/11 09:46 PM
03/12/11 09:46 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
with the man above me in the thread
Re: Vacuum Pump [Re: fishy340] #949245
03/13/11 07:30 PM
03/13/11 07:30 PM
usa
9
90ram Offline OP
90ram  Offline OP
usa
Thanks Guys
