No Rear End Fluid #948597
03/11/11 04:22 PM
03/11/11 04:22 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
71 Cuda project car has a B body 742 rear in it. No fluid since the chuck was changed by the previous owner. The rear brake shoes and hardware were all brand new, so I suspect he also did the axle seals. When I fill this rear, where could I expect leaks?
Grandma always said I had "hands of gold"!
Re: No Rear End Fluid [Re: CHRGR69] #948598
03/11/11 04:29 PM
03/11/11 04:29 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Out the axle ends or at the diff itself if he didn't use RTV or a gasket. I've swapped chunks without replacing the seals and got lucky and they didn't leak.
Re: No Rear End Fluid [Re: ireland383] #948599
03/11/11 04:32 PM
03/11/11 04:32 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Out the axle ends or at the diff itself if he didn't RTV or a gasket.
OK that's what I'm thinking. Don't want to pull the axles. I'm hoping new brake hardware is a sign of new seals.
Re: No Rear End Fluid [Re: CHRGR69] #948600
03/11/11 04:34 PM
03/11/11 04:34 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I edited my post.
Re: No Rear End Fluid [Re: ireland383] #948601
03/11/11 04:35 PM
03/11/11 04:35 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
I edited my post.
Got it!
