Re: How much have these hemi heads been milled?
[Re: DaytonaTurbo]
#948550
03/11/11 03:06 PM
03/11/11 03:06 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Yes,measure the chamber depth (to the deck) in the center of the chamber.The spec is available in all the old Mopar books and tune up tips.May be in the tech archives here.
Leave the gun.......take the Cannoli's....Mike
[Re: moderncylinder]
#948553
03/11/11 04:45 PM
03/11/11 04:45 PM
DaytonaTurbo
Manitoba, Canada
i have in records that an uncut head thickness is 3.675
just cc the chamber
Would but don't have valves to fit.
[Re: DaytonaTurbo]
#948556
03/11/11 06:47 PM
03/11/11 06:47 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
unless you have a 64 car,, go buy some stage v heads,, sell those to a restoration guy....
i said before,, guys cut the intake flanges more than what they should have for how much the deck of the head was cut,, if you had a crossram and you cut .100-.150 off your block the only option you really had then was to cut the intake face of the head
[Re: hot67cuda]
#948558
03/12/11 06:37 AM
03/12/11 06:37 AM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
Yeah, I would say get rid of them and get good ones. All sort of issues hard to come by: intake bolts do not fit, valveseats sticking out are cut, then valves are sunk, then rocker geometry is wrong, then interference with valvecovers, if you put on extra valvecovergaskets the sparkplug tubes are too short etc, it is really an endless nightmare and the absolute opposite of blueprinting. Gosh a Hemi can be screwed up by all jobs done to it in its earlier life, the shortblock can be equally bad (by multiple line-honings) I am assembling a Hemi now with new block and heads, and it is like a sweet dream. It is a good mock-up instead of a bad fcck-up. I would say, that is a good investment, and will really cut down on working hours, not to mention the degree of quality you gain. My
#948559
04/18/11 10:40 PM
04/18/11 10:40 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Is this measurement for a 559 head? Where are the reference locations on the head?
[Re: Snoopy]
#948560
04/19/11 12:17 PM
04/19/11 12:17 PM
Posts: 3,505 DFW
mr_340
DFW
I have a drawing on the 3614433 aluminum head and it shows a dimension of 3.68" from the deck to the rocker stand pad. Nominal chamber depth is 1.34". Attached is a quick drawing I did on the basic chamber shape. I was trying to see how much cc's would be added if I machined the R.25" to the full radius. It was less than 1cc added.
Floyd Lippencott IV
