Oil Pressure vs High RPM's ? #948528
03/11/11 02:43 PM
03/11/11 02:43 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
My 383 runs about 20+ psi at idle with a a hot engine (180 to 190) and 52 psi at 6,000 RPM's. Am I starving the engine of oil at 6k? It's a Milling street pump. Running 15W40 oil.
Can someone explain pressure vs volume?
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Oil Pressure vs High RPM's ? [Re: Junky] #948529
03/11/11 02:45 PM
03/11/11 02:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Pressures are fine don't worry about it.
Re: Oil Pressure vs High RPM's ? [Re: Junky] #948530
03/11/11 02:47 PM
03/11/11 02:47 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Thats a little low for 6,000rpm but still adequate.
With 15w40 oil I am thinking you have somewhat loose clearances, meaning its easy to flow oil through the block/rods etc and hard to build pressure.
You might want to try a HV pump (NOT HP), the HV pump will flow MORE oil per revolution, and therefore have an easier job building pressure.
Re: Oil Pressure vs High RPM's ? [Re: Pacnorthcuda] #948531
03/11/11 03:00 PM
03/11/11 03:00 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
At 6000 rpms the pressure would have to be less than 35 to literally starve the engine.That is it would be the minimum to overcome inertia per bearing size.However the pressure is low for 6000 rpm.10 psi per 1000 rpm is a safe minimum.Somewhere you are leaking pressure.
Leave the gun.......take the Cannoli's....Mike
Re: Oil Pressure vs High RPM's ? [Re: Pacnorthcuda] #948532
03/11/11 04:36 PM
03/11/11 04:36 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Thanks for the assurances guys. I may get a Milodon adjustable pressure relief valve to raise it a tad.
Re: Oil Pressure vs High RPM's ? [Re: Junky] #948533
03/11/11 04:42 PM
03/11/11 04:42 PM
That is likely to not raise it all. Does the pressure go over 60psi when cold (I bet it does), or does it top out in the 50's???
Your current pressure valve/spring is likely NOT operating in the 50's (and it shouldn't).
You don't have enough flow, with that weight oil, to build more psi than what you are seeing.
A HV pump, or heavier oil (20w50, because its harder to push through small spaces) will increase your hot pressure.
So will fixing the root cause--likely excessive main/rod bearing clearences.
Re: Oil Pressure vs High RPM's ? [Re: Pacnorthcuda] #948534
03/11/11 10:17 PM
03/11/11 10:17 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Cold, warming the engine up at 1700 RPM's the oil pressure is close to 52 psi.
Re: Oil Pressure vs High RPM's ? [Re: Junky] #948535
03/11/11 11:34 PM
03/11/11 11:34 PM
IN
ahy Offline
ahy  Offline
IN
If its 52 cold, it may just be a regulator spring on the low side of tolerence. The adustable spring may fix it. While I've never done it, I understand its also possible to simply shim up the existing spring with small flat washers.
Re: Oil Pressure vs High RPM's ? [Re: stumpy] #948536
03/11/11 11:43 PM
03/11/11 11:43 PM
Pressures are fine.
what Stump said, You're good
Re: Oil Pressure vs High RPM's ? [Re: RapidRobert] #948537
03/12/11 12:01 AM
03/12/11 12:01 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Pressures are fine.
But it is low and you might want to know why.
Re: Oil Pressure vs High RPM's ? [Re: Junky] #948538
03/12/11 12:10 AM
03/12/11 12:10 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
what size pan do you have ?
Re: Oil Pressure vs High RPM's ? [Re: BSB67] #948539
03/12/11 01:03 AM
03/12/11 01:03 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Pressures are fine.
Why do you think that's low. Unless it's a brand new no mile motor those pressures are fairly normal if that is an in gear at idle 20psi. My 408 runs about 60psi at 6500 and 20psi in gear at idle(750 rpm}. After racing it for 2 years at those pressures I still show very little bearing wear.
Re: Oil Pressure vs High RPM's ? [Re: stumpy] #948540
03/12/11 03:05 AM
03/12/11 03:05 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
It's a 4 quart pan one that's on a '71 383. I run a windage tray. With new oil filter I run 5 quarts of oil.
20 psi, hot engine, in gear at idle, foot on break. It actually fluctuates from 20 to 25 at idle, since idle is slightly up and down due to the cam. Idle is 750 RPM.
I asked this question because of so many people saying that oil pressure should be 10 psi per 1,000 RPM. It's just always bugged me not having 60 psi at 6k. Don't wanna hurt the engine.
I gotta say I trust RapidRobert and stumpy's opinion.
Re: Oil Pressure vs High RPM's ? [Re: stumpy] #948541
03/12/11 09:28 AM
03/12/11 09:28 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Pressures are fine.
I did not say it is a problem. I believe that it is low enough that it is worth looking into and understanding why. I know nothing about his build. If its a motor with 0.003" rod and main bearing clearances, full groove mains, designed to put a lot of oil up top, and has a std pump pressure relief spring - it makes perfect sense - would not change a thing.
But, if its a stock rebuild with stock clearances, half groove mains conventional oiling, 15/40 oil, and the pump is good (not to necessarily confuse a new Melling pump with good), then something is not right or not what it should be. Is it enough to matter, probably not.
Re: Oil Pressure vs High RPM's ? [Re: Junky] #948542
03/12/11 09:30 AM
03/12/11 09:30 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Okay
Re: Oil Pressure vs High RPM's ? [Re: ahy] #948543
03/12/11 02:25 PM
03/12/11 02:25 PM
Agreed. Junky--if your cold PSI tops out at 52psi (same as your hot) then that's indicative of the pressure bypass valve in the pump opening up, and 52 is on the low side.
Simply take off the big nut at the back of the pump and find a washer or 2 that will fit inside the Nut/cap. That preloads the spring a little more and makes the valve (its a metal cylinder that uncovers a dump-port when under pressure) harder to move into the bypass position.
You will notice higher pressure.
I have done it, and in your case I think it will work.
Easy.
Re: Oil Pressure vs High RPM's ? [Re: Junky] #948544
03/12/11 02:53 PM
03/12/11 02:53 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
I would be a little concerned about pumping all the oil outa'-da'-pan. If I were you ...I would look-into buying a larger capacity pan.
FOR NOW ... make sure you DO get the oil nice-and-warm before you take-it up-to 6,000 rpm.
Re: Oil Pressure vs High RPM's ? [Re: Pacnorthcuda] #948545
03/12/11 04:52 PM
03/12/11 04:52 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Easy.
Good to know that. Thanks. I'll try the shim.
Re: Oil Pressure vs High RPM's ? [Re: dOrk !] #948546
03/12/11 04:56 PM
03/12/11 04:56 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I never run the engine hard until it's up to operating temp. I'm not like some of these guys that take off from a car show or cruise-in, after setting hours, doing burn outs or red lining their engines through the gears leaving. That's really hard on parts!!!
Re: Oil Pressure vs High RPM's ? [Re: Junky] #948547
03/12/11 06:21 PM
03/12/11 06:21 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Easy.
My 383 was exactly the same psi as yours a bit higher at idle (900 rpm) i installed the hi psi spring now it stays at 72psi anything over 1500 rpm, but obviously the idle psi is the same. you should be fine just the way yours is now but add the spring if your worried
