5.7 hemi MSD ignition question #948411
03/11/11 11:31 AM
03/11/11 11:31 AM
Bowling Green, KY
cudaboy Offline OP
cudaboy  Offline OP
Bowling Green, KY
http://www.fasthemis.com/6013---msd-6-hemi-ignition-controller-for-5.7l-and-6.1l-hemi.aspx
Is the above item, along with the MSD wiring harness, what I would use for a Hemi install into an older car using a carb? I wouldn't need the factory computer nor harness, right?
Dennis
Re: 5.7 hemi MSD ignition question [Re: cudaboy] #948412
03/11/11 11:55 AM
03/11/11 11:55 AM
dearborn heights michigan usa
brianw Offline
brianw  Offline
yes that with the harness is all you need .
Re: 5.7 hemi MSD ignition question [Re: brianw] #948413
03/11/11 02:04 PM
03/11/11 02:04 PM
Bowling Green, KY
cudaboy Offline OP
cudaboy  Offline OP
Bowling Green, KY
Thanks Brian, that was what I was hoping.
Dennis
