413 Heads #947938
03/10/11 08:31 PM
03/10/11 08:31 PM
Huntington, Indiana
DartDad Offline OP
DartDad  Offline OP
Huntington, Indiana
Is there any advantage in using 413 closed chamber heads on a 440?
Re: 413 Heads [Re: DartDad] #947939
03/10/11 09:10 PM
03/10/11 09:10 PM
Jorsey
P
Polaraco Offline
Polaraco  Offline
P
Jorsey
As far as I know, they are the same, but the casting numbers may be the same
Re: 413 Heads [Re: DartDad] #947940
03/11/11 03:44 AM
03/11/11 03:44 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
higher compression .
smaller ex valves , larger ones can be installed .
casting number 516
what years are the engines you are working with ?
Re: 413 Heads [Re: calrobb2000] #947941
03/11/11 04:12 AM
03/11/11 04:12 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
There are early 413's & 383's with the 1.75 exh valve 4 bolt covers and stands for the rockers.Letter cars w/ram intake,383 8 barrel(915's?) and 413 2 four barrel engines.Harder to find but out there.Also the 63 300J had 915's with the old shaft assembly and 4 bolt covers.They didn't appear again until 67 with cast in stands and 6 bolt covers.You will need hard exh seats added.Unless you can do the work yourself it is probably cheaper to buy the aluminum heads out there.To me 516 heads aren't worth the effort (port match bowl port,valve guide work,hard seats and parts), flow poorly and are very prone to cracking with a large exh valve. A set of stealths or eddies look pretty good and really flow a great deal more air.
Leave the gun.......take the Cannoli's....Mike
