Trying to make Gas Gauge Work.. Help Please.
#94764
07/26/08 06:11 AM
07/26/08 06:11 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
New gas tank, new sending unit. I quickly touched the back of the gauge with 12v and the needle moves fine. Sending unit ground new and grounded.
I tried grounding the sending unit lead and the needle did not move. Traced wiring back to harness all looks good.
Ok, so now I moved to the gauge cluster itself. I am only looking to make the gas gauge work so it is the only gauge hooked up factory. I am using custom gauges for everything else. All wiring is stock and not cut up.
I replaced the voltage limiter with a few others I have.. nothing.. So I am down to the 8-prong connector on the circuit board. I only seem to get power from one of the prongs. All others are dead. Is this the prong that feeds the board? Is this how it should be? I see other prongs going to the fuel gauge and temp gauge etc. These prongs are dead. Shouldn't it be live?
RS23L7 4-Speed
Re: Trying to make Gas Gauge Work.. Help Please.
[Re: Cudajon]
#94767
07/26/08 09:56 AM
07/26/08 09:56 AM
RapidRobert
Michael take the sending unit lead wire off of the sending unit & connect this wire to the battery NEG post with a long jumper wire(with an alligator clip on each of the ends) turn ign key on & see if gas gauge needle goes to full & holler back please.
[Re: stubbs300 ]
#94769
07/26/08 01:52 PM
07/26/08 01:52 PM
Mopar_Mike
Danville, NH
Guys, Thanks for all the responses. I got it to work!! I had everything apart (except tank and sending unit, thank god..) but I had the dash out. I tested current to one side of the gas gauge and then it was on the other as well.. Now the other side is the wire that feeds the prong that becomes the wire to the sending unit. I did not have power there.. so I tightened the barrel nut on the gas gauge and that made a better connection to the circuit board and hence gave me the .5V back to the sending unit and bingo, gas gauge worked.
RS23L7 4-Speed
[Re: Mopar_Mike]
#94770
07/26/08 04:55 PM
07/26/08 04:55 PM
RapidRobert
I'm glad you didn't fry it when you put 12V to it.
