Building a strong 904? #947575
03/10/11 01:45 AM
03/10/11 01:45 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I've asked this question at a few sites. I have 727 rebuilding experience, but no 904 experience. I get many responses that say to just drop 727 guts into a 904 case to make it stronger, but these responses are not specific.
Okay, that all sounds good, but it begs the question: Since the cases are somewhat different in size, will everything transfer over between them? Or are there some areas where I will encounter problems? What won't fit? What, if anything from the 904 should be retained? Any responses will be appreciated.
Re: Building a strong 904? [Re: polkat] #947576
03/10/11 01:55 AM
03/10/11 01:55 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
727 parts are not going to fit into a 904 case....so ever is telling you that dont know anything about 904s
use good alto disc...kolene steels...and good bands...
Tony
70 AARCuda Vitamin C
Re: Building a strong 904? [Re: 70AARcuda] #947577
03/10/11 02:30 AM
03/10/11 02:30 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
x2 ...NO WAY will 727 parts fit in a 904
What ROCKET SCIENTISTS have been telling you that they will ? You can put-together a real decnt 904 with stock-stuff ... not to worry.
Re: Building a strong 904? [Re: BeEtLeJuIcE !] #947578
03/10/11 11:47 PM
03/10/11 11:47 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Okay, well, lets talk about it some. This is the original slant 6 904 that will go back behind the built up slant. Other then the silly 727 into 904 stuff, I've also heard to empty the 904 case and install A998 or 999 internals. What problems will I run into trying that? Could I just install the drums and gearsets? Maybe the input shaft? Or are other parts from the original 904 still too weak? Any writeups on doing this anywhere?
Re: Building a strong 904? [Re: polkat] #947579
03/11/11 12:16 AM
03/11/11 12:16 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
First, you will get a lot more accurate answers if you state what you are trying to do - street car, drag race, a little of both. And with what - car, horsepower, gear ratio, etc. It is IMPOSSIBLE to answer your Q's without this info. Next, you need to decide what type of valve body (V/B) you want to use - full auto w/linkage, stock V/B w/shift kit, reverse pattern, reverse w/low band apply, etc. Why? Because all the good hard parts WILL NOT LAST with a crap V/B. Also, you don't need high $ clutches, bands, steels for a stock rebuild. So after you post what you are trying to do and what you are trying to do it with - I bet you will get some good advise on how to build your trans.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Building a strong 904? [Re: Evil Spirit] #947580
03/11/11 01:07 AM
03/11/11 01:07 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I agree, The VB is one of the most important parts of the trannys life (its basically the "heart"), A warn out or stock VB & the parts will not hold up to much abuse (even heavier clutches/bands ect.), I ran a "stock" rebuilt 904 with nothing but a Cheatah FMVB & re-adjusted the bands & the tranny was kick-ass.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Building a strong 904? [Re: joedust451] #947581
03/11/11 03:16 AM
03/11/11 03:16 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
The car is an early 70's Dart 2 door. The original 225 slant 6 will be turbo'd for between 250-300HP. Building for street/strip. Will use the stock valve body with a Transgo kit, maintaining the auto function. Rear is a 8-1/4" with 3.23's.
Re: Building a strong 904? [Re: joedust451] #947582
03/11/11 03:22 AM
03/11/11 03:22 AM
Florida STAYcation
Florida STAYcation
GUYZ .... what is this crap VB thing ?
I have done plenty of TF's and I have maybe found one or two TF's that had faulty VB's.
You have to TWEAK a stock VB for a HP application ... but you do not need a high$ piece to make-it-live OR make it perform well.
Re: Building a strong 904? [Re: polkat] #947583
03/11/11 05:56 PM
03/11/11 05:56 PM
Edmonton, Alberta, Canada
Dartman75 Offline
Dartman75  Offline
I don't think you need anything super special to make a 904 happy behind a turbo'd slant in that power range (assuming torque is around similar levels). The key is quick shifting valve body with higher line pressures to hold things. My tranny runs 190 or 210 (can't recall) with a 4.2 lever and I put around 550 ponies though it and only slightly less torque. Mine is a 999 case and internals because the case is supposedly stronger than the early 904's, and it had a low gear set (2.74 instead of 2.54). For whta you're building, you don't need a limits pushing setup, or even the setup that I run. A good basic build with an eye to quality clutches bands and good Valvebody selection and you'll not have a problem.
BTW, I love the idea of a turbo slant
Greg
Re: Building a strong 904? [Re: Dartman75] #947584
03/11/11 08:30 PM
03/11/11 08:30 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Sadly, a small block V-8 998-999 won't bolt to the slant block, which is why I was thinking of putting the 999 guts into the slant case. But I DON'T want a lockup converter, which I understand the 999's had. What can I do about that? Seems no one here has done this.
Re: Building a strong 904? [Re: polkat] #947585
03/11/11 09:23 PM
03/11/11 09:23 PM
But I DON'T want a lockup converter, What can I do about that?
I'd wait for Kunkel for the final word on this but I think you can swap the input shaft/front clutch assy for a non LU set. I built a 904 w stock stuff & roundy round raced it & zero probs, next one I'd use better materials as mentioned the kolene steels/raybestos discs etc iirc & no opinion on the VB comments but ran into a drag racer way back who swore by the turbo action VB as the only way to go w a Frank Lupo Dynamics converter but it was a quarter miler only
Re: Building a strong 904? [Re: polkat] #947586
03/11/11 09:25 PM
03/11/11 09:25 PM
Put any power to it and be ready to start replacing front pumps.
My mild street 318 with 360 heads combo (right at 300hp) used to destroy front pump ears on my 904 about every 6 months on cue.
Re: Building a strong 904? #947587
03/12/11 12:55 AM
03/12/11 12:55 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Then you were doing something wrong. 300hp in front of a stock 904 shouldn't be an issue, period. If you were losing front pumps something else was wrong, probably trans to engine alignment.
Don't be the exception.
Re: Building a strong 904? [Re: Supercuda] #947588
03/12/11 01:00 AM
03/12/11 01:00 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
No trick parts needed to make a 904 live for years with more HP than the op wants to make.
Re: Building a strong 904? [Re: BeEtLeJuIcE !] #947589
03/12/11 01:44 AM
03/12/11 01:44 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Ok then.... Please advise US of things that can be done for different HP levels sense you know these things , we are ALL ears
Re: Building a strong 904? [Re: joedust451] #947590
03/12/11 01:46 AM
03/12/11 01:46 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
No, probably not necessary, but the reliability factor goes up with stronger parts.
But i was not asking if I should do it, but HOW to do it.
Re: Building a strong 904? [Re: polkat] #947591
03/12/11 02:18 AM
03/12/11 02:18 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I guess this subject come up once a month or so about how 904 can not hold the power...
i been using a 904 ...the same 904 since 1993 in my 69 Barracuda that has run 10.70s out here in las vegas..
it has been rebuild once back in 2004...
the 904 has the same pump...only part that has broken was the rear sprag due to ring and pinion breaking....
904 has 5 disc in front clutch pac...uses kelvar bands and alto disc/kolene steels..
the big spring in the front clutch pac has been replaced with a 24 spring kit...
been using the same tranzact pro transbrake since 1993...so the poor little 904 is getting slammed with a transbrake too...
got another 904 going on it 4th season...same parts as above in 71 dart that has gone a best of 11.03...while changing engine last month...I took this 904 apart to check it out..everything looked great...just replace sealing rings ...it is back in service...
car is on trailer to go racing tomorrow...
so if you are breaking parts...find another trans guy..or read a book...
Tony
Re: Building a strong 904? [Re: polkat] #947592
03/12/11 02:32 AM
03/12/11 02:32 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Items of interest. Most of the interchange issues is in the front pump/converter/input shaft area. First concern is the lockup/non lockup converter/pumps - obviously you want a non lockup pump/input shaft. Second issue is the "weakness" of the pump. There has been breakage issues with the converter drive ears cracking/breaking off. The solution is to have the converter made with a moly drive stub and use the A&A billet pump gear, or have the converter and pump converted to A500 parts (have flats instead on slots). Now you are up to input shaft/direct drum and pump compatibility - there are a couple different size hubs where the sealing rings seal to the pump, so make sure that you have a match there. Also, if you use a 5 clutch direct (Front) drum, you have to use the matching pump with the clearance ground for the larger drum, or grind it. Ideally, if you could find a non lockup 999 you could pretty much drop in the guts as a whole, but personally I haven't tried to do a slant 6 trans conversion, and it's hard to envision every step online. If I was piecing one together, I'd look for the 2.74/1.54 (low) gearset, 4 clutch forward (rear) drum, a 4 clutch direct(front)drum would work, but a 5 would be nice, and probably use a 4.2 kickdown band lever. New stock clutches and band would last, premium would last longer. This isn't a complete step by step to your build, but I hope it steers you in the right direction. Hopefully someone like John Kunkel will fill in the blanks for you.
Re: Building a strong 904? [Re: Evil Spirit] #947593
03/12/11 02:42 AM
03/12/11 02:42 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i put 5 disc in the 4 disc front drum..and using the stock 2.45 gearing.
Tony
Re: Building a strong 904? [Re: 70AARcuda] #947594
03/12/11 04:43 AM
03/12/11 04:43 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Evil Spirit said...
>"Ideally, if you could find a non lockup 999 you could pretty much drop in the guts as a whole..."
That's pretty much what I wanted to know, and I understand that the pre 80 999's (found particularly behind 360's) were non-lockup. Unless anyone disagrees with this, I'll take it from here. Thanks!
