Need photo Challenger Brake Line route across Firewall #947546
03/10/11 12:37 AM
03/10/11 12:37 AM
Tenn.
jrwoodjoe Offline OP
Tenn.
Can someone post a photo of correct path across the firewall of the Front Right Side Brake line? I want to make sure my bends are correct.
Thanks, Joe
65 Barracuda
70 Challenger
Re: Need photo Challenger Brake Line route across Firewall [Re: jrwoodjoe] #947547
03/10/11 12:56 AM
03/10/11 12:56 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
There are a couple 71 cuda firewall pics on RestoRicks website. I imagine the Challenger would use the same brake line routing????
http://www.restorick.com/Resto/71hemicudagreen2.htm
Re: Need photo Challenger Brake Line route across Firew [Re: Neil] #947548
03/10/11 01:08 AM
03/10/11 01:08 AM
Tenn.
Tenn.
Thanks Neil, that is helpful.
Re: Need photo Challenger Brake Line route across Firew [Re: jrwoodjoe] #947549
03/10/11 10:16 AM
03/10/11 10:16 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Disc brakes.
Re: Need photo Challenger Brake Line route across Firew [Re: Challenger 1] #947550
03/10/11 12:20 PM
03/10/11 12:20 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
My 73 looks like the above but my 72 had the line go over the rail and exit thru the rubber flap. sorry no photo's
Gary
Re: Need photo Challenger Brake Line route across Firew [Re: Mr340] #947551
03/10/11 12:26 PM
03/10/11 12:26 PM
Cincinnati, Ohio
Cincinnati, Ohio
Gary
I was thinking that when I posted the picture, I think when it comes thru the rubber flap, if is for drum brakes? Cause this car had drum originally and I remember the lines coming thru the flap. I may be wrong about that but that's what I recall.
Re: Need photo Challenger Brake Line route across Firew [Re: Challenger 1] #947552
03/10/11 01:57 PM
03/10/11 01:57 PM
Tenn.
Tenn.
Excellent Pic Gary. Thanks for posting it. One interesting thing I have noticed is that my car does not have that far right hold down clip it just has the 2 on the left.
Thanks again Gary, Happy Birthday too.
Re: Need photo Challenger Brake Line route across Firew [Re: jrwoodjoe] #947553
03/10/11 03:14 PM
03/10/11 03:14 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Thats because the 70 brake line routs different on the pass side then the 71 up line. The 71 and up cars had the pass side brake line UP over the frame rail ( not under like the above pics) on the line goes through the rubber splash sheild. Yes BOTH af my cars are 71 DISK brake. Maybe some very early build 71 cars are like Garys pics above. The 70 line also take a shortcut from the firewall to the inner fender and does not go into the corner like a 71 up line and thats why the last clip on the firewall is missing.
