Want to paint my 8 3/4 #947240
03/09/11 06:40 PM
03/09/11 06:40 PM
Fresno, California
msanchi Offline OP
msanchi  Offline OP
Fresno, California
I am getting close to putting an 8 3/4 under my Challenger.
The housing came with the car but needs to be cleaned of rust and dirt and painted. The axles are still in the housing but the third member is not. What is the best way to clean and prep it to be painted? Should I have it blasted or run a drill and wire brush? Will a little surface rust be a problem? How about the inside, how is that cleaned up? Also Any special prep on the axle shafts before re-use with a rebuilt carrier,new bearings and seals?
1970 Dodge Challenger Project (440, 915 Heads, 727 Trans)
Re: Want to paint my 8 3/4 [Re: msanchi] #947241
03/09/11 06:54 PM
03/09/11 06:54 PM
Under My Car
Mopar_Country Offline
Under My Car
I just cleaned mine real good, maybe hit the rusty areas with some sandpaper to clean them up. Prime and paint. If you are unsure of the seals now would be the time to replace them. Get a needle for your grease gun and a good quality wheel bearing grease and pack the bearings as that is the only lube they get.
Re: Want to paint my 8 3/4 [Re: Mopar_Country] #947242
03/09/11 08:10 PM
03/09/11 08:10 PM
I bought a roller (65 Dart) w a powdercoated 8&3/4 & it does look nice, much better than rattle canned finishes & no comparison to bare cast. Not sure how they prepped it but after seeing it I'd want that quality again
Re: Want to paint my 8 3/4 [Re: msanchi] #947243
03/09/11 08:59 PM
03/09/11 08:59 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
POR-15, or Rust Bullet is good.
Jut dont get it on your hands.
Re: Want to paint my 8 3/4 [Re: POS Dakota] #947244
03/09/11 10:19 PM
03/09/11 10:19 PM
Under My Car
Under My Car
Mine didn't turn out too bad for a spray bomb.
Re: Want to paint my 8 3/4 [Re: Mopar_Country] #947245
03/09/11 11:08 PM
03/09/11 11:08 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I cleaned mine with heavy duty EZ-Off oven cleaner then painted it with high performance Rustoleum
Ride eternal, shiny and chrome
Re: Want to paint my 8 3/4 [Re: msanchi] #947246
03/09/11 11:21 PM
03/09/11 11:21 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I blasted mine and epoxy primered it. I am gonna leave it like that now for mock up.Gotta weld on 4 link tabs ect. But I plan on Eastwood chassis black and clear
Re: Want to paint my 8 3/4 [Re: johnscudashop] #947247
03/10/11 05:43 AM
03/10/11 05:43 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Just make sure its free of all dirt and grease before you paint it. You could also rhino line it. But what ever you do, it needs to be clean. Surface rust will cause the paint to lift off and spread. If you have the funds, have it blasted. You can put high dollar paint on a crappy prep job and its going to look crappy. You can put cheap paint on a well prepped part and it will look good and last longer. The beauty is in the prep, then the paint.
Re: Want to paint my 8 3/4 [Re: None2Slow] #947248
03/10/11 08:01 AM
03/10/11 08:01 AM
scratchnfotraction Offline
sandblasted and used rustoleum gloss black on mine
washed inside with ez off oven cleaner and rinsed
clean,repack axle bearings,install new seals while its apart
dont for get to doll it up with lipstick some also
Re: Want to paint my 8 3/4 [Re: scratchnfotraction] #947249
03/10/11 08:02 AM
03/10/11 08:02 AM
my other one
Re: Want to paint my 8 3/4 [Re: msanchi] #947250
03/10/11 09:14 AM
03/10/11 09:14 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
We had leftover auto paint in black base/clear from our Challenger's tail panel so we painted the 8 3/4 with that. 2 coats of base and 6 coats of clear, it's durable as heck now. ha
Re: Want to paint my 8 3/4 [Re: dustergirl340] #947251
03/10/11 08:12 PM
03/10/11 08:12 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Sandblasting gets things so clean, I recommend it when possible. I plugged the vent and went at it, then primed/painted it with urethane car paint. The center section is Eastwood cast iron paint, the nuts are self locking from a local hardware store. Cheap and easy. Before:
Re: Want to paint my 8 3/4 [Re: 4BBodies] #947252
03/10/11 08:13 PM
03/10/11 08:13 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
After Blasting:
Re: Want to paint my 8 3/4 [Re: 4BBodies] #947253
03/10/11 08:14 PM
03/10/11 08:14 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Final Product:
