Help! 66 Coronet Stering Columns
#947086
03/09/11 01:05 PM
03/09/11 01:05 PM
Posts: 412 Jackson, Mississippi
CornDogsCharger
I am working on a 66 Coronet at the shop that was originally an automatic on the column. I am coverting it to a floor shifted automatic. In doing so I have located a steering column to dothe conversion. This column does not have any kind of bearing or support for the steering shaft. Is this correct or am I missing some parts? Thanks for your help. Justin "CornDog"
1966 Dodge Charger 1968 Plymouth Satellite (Un-Restored "Survivor") 1969 Dodge Charger (W.B. General Lee) 1969 Dodge Charger (Future DMCL Clone) 1969 Dodge Super Bee, 383 4spd
Re: Help! 66 Coronet Stering Columns
[Re: CornDogsCharger]
#947088
03/09/11 01:34 PM
03/09/11 01:34 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I'm not 100% certain, but I believe there is no bushing. On my 1970 e-body, the steering shaft itself is held in place by the steering coupler & steering gearbox. Positioning the plate that attaches to the floorpan is what centers & locates the larger tube in relation to the shaft.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#947089
03/09/11 03:44 PM
03/09/11 03:44 PM
CornDogsCharger
I would think the 70 model stuff would have a lower bearing because even though it may not be column shifted, it would still have the linkage to disengage the ignition switch. I know it that way on the b bodies but I'm not sure on the e bodies.
Justin "CornDog"
[Re: kdhull]
#947091
03/09/11 05:31 PM
03/09/11 05:31 PM
CornDogsCharger
I was looking at the same diagram on my parts manual but it is for the full size car like a Monaco or fury. The other columns in the manual are all column shifted cars. Maybe I missed something.
