Re: 518 with two pressure switches setup question?
[Re: hemibeep]
#946948
03/09/11 11:41 AM
03/09/11 11:41 AM
Posts: 2,256 IL
furious70
IL
My a500 conversion stays locked up until it downshifts, it does not come out of lockup coasting or hitting the brakes like OEM.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: 1_WILD_RT]
#946950
03/09/11 12:57 PM
03/09/11 12:57 PM
Posts: 2,256 IL
furious70
IL
I agree, my 2 adjustable psi switches for upshift and hobbs switch for kickdown don't give it complete OEM functionality, but for me going the additional steps you took were more work/money then I saw benefit in for a non-daily driver.
[Re: 1_WILD_RT]
#946952
03/09/11 02:40 PM
03/09/11 02:40 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
dunno, I'm using a GM NO vacuum switch hooked to manifold vacuum on the ground leg, and IIRC a 38 & 45 PSI switch on the LU and OD. mine locks up ~ 25mph and unlocks at the same, and OD kicks on at ~37mph and unlocks at the same (using 3.55 gears with 27" tires). I installed a trans go TF-OD kit, don't know if that messed around with governor pressures at all.
best bet, try find some higher PSI switches, at least for OD, something like 60-65psi?
[Re: patrick]
#946953
03/09/11 03:05 PM
03/09/11 03:05 PM
Posts: 1,513 AZ
Mike P
AZ
Please keep us posted on what you come up with, I'm going to be going this route with a 4.56 gear and 28" tall tire and was wondering about the pressure switches.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: patrick]
#946954
03/09/11 04:48 PM
03/09/11 04:48 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
How is that in your application?
I didn't like how my 1998 1500 drove with lockup and OD coming in under 40mph ? The 78 Lebaron with a 318 was even worse ....
[Re: JohnRR]
#946955
03/09/11 06:26 PM
03/09/11 06:26 PM
patrick
Grand Haven, MI
those upshift/lockup points are happier with my mag headed/hyd. roller cammed 318 than my comp XE262 equipped 360
