Re: too much cranking compression?
[Re: moturbopar]
#946902
03/09/11 03:49 AM
03/09/11 03:49 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
how thick is your head gasket?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: moturbopar]
#946904
03/09/11 03:58 AM
03/09/11 03:58 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
A long duration cam tends to actually bleed off cylinder pressure. I have read that a rough guideline for the pump gas limits are 200-230 psi cranking pressure. When I built the 440/493, I advanced the '509 cam by 4 degrees. It had cranking numbers in the 230 range. Later when I returned the cam to a straight up position, it was down in the 190s. The advanced position closed the valves earlier in the cycle, so MORE pressure was evident.
[Re: Kern Dog]
#946905
03/09/11 04:26 AM
03/09/11 04:26 AM
Posts: 3,281 West Coast, USA
jbc426
West Coast, USA
I heard the limit was closer to 175psi in a well-sorted and highly tuned motor. Mine's got 225psi, and I have to run 100 octane unleaded.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: moturbopar]
#946906
03/09/11 04:28 AM
03/09/11 04:28 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Hi all the 360 Im building will have 9.4 to 1 mechanical, and I will be running a comp cams xe268. The heads are regular open chamber small block heads the chambers deburred and some polishing. I have been told it might have too much cranking compression to run on pump gas!!??
If so do you guys think that the comp xe274 would be a better choice to bleed of some cylinder pressure? Thanks
You should be fine with the comp XE268 cam. The cam (if installed per spec) closes the intake valve 60 degrees after bottom dead center (ABDC.) If you plug the info into the Wallace Racing Calculator for Dynamic compression/cranking pressure you get 146 cranking PSI at your altitude of 1,241 feet. Even at sea-level (0 Feet altitude) the cranking pressure would only be around 153 PSI.
Links: http://www.wallaceracing.com/dynamic-cr.php http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=627&sb=0
[Re: moturbopar]
#946910
03/10/11 12:13 AM
03/10/11 12:13 AM
Posts: 923 Missouri
convertriple
super gas
super gas
Missouri
My 340 has 9.5:1 static compression using TRW's old 10.5 flattops. I use an 80's version of the 280/.474 MP purple shaft cam, which I read waaay back when, builds compression. This same motor ran awesome in the 80's, but fuel quality is so poor now , I ping at 32 degrees total on 93 octane. My cranking PSI is around 190. To be fair, I haven't messed with the timing curve yet, and have to experiment with jets more, hopefully one of those can help me.
[Re: moturbopar]
#946915
03/10/11 05:09 AM
03/10/11 05:09 AM
451Mopar
Aurora, Colorado
I think the XE268 would be fine, but if you really want cam suggestions we really need more information. How did you figure the 9.4:1 compression? Which pistons (type, valve reliefs, dish/dome?), cylinder head volume size?, head gaskets? What valve sizes? any head porting? Intake manifold/carb, exhaust system, tire size,etc.
[Re: 451Mopar]
#946917
03/10/11 01:46 PM
03/10/11 01:46 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
my 318 with magnum heads, stock pistons .055 in the hole (no quench) and a reground roller cam runs at 155-160 PSI on a compression test, and I have no problems running 87 octane...you'll be fine
[Re: moturbopar]
#946919
03/11/11 12:30 AM
03/11/11 12:30 AM
451Mopar
Aurora, Colorado
I like those pistons. I used the KB232 D-dish with quench pad and they added alot of extra machine work to get them set up correctly. I checked the numbers you posted and they look good, I got 9.41:1 compression? Your tire height looks to be about 26", so with the 3.55 gears 65MPH would be about 3,000 RPM. With your car weight, converter stall, and gear/tires size you could go with the XE274 cam. On the dyno simulation, it does not show much difference between the XE268 and XE274 cams. I think the simulation may be limiting upper end power because of the exhaust flow numbers I used (147cfm@0.500".) When the cams were installed per spec at 106 intake cl, the xe274 gives up about 4hp at 2,600-2,800 RPM (your stall speed), and only gains about 3HP at peak HP around 4,400 RPM. The xe274 stays around peak power longer before dropping off. Because the simulation thinks the exhaust is a bit restrictive, advancing the installed CL of the cams (102 degrees looks good) improved the power output of both cams. With the xe274 cam installed at 102 degrees I got peak HP of 317@4,400RPM, and 410 ft/lbs @ 3,400 RPM. I then entered the flow numbers of the Edelbrock heads which have pretty good exhaust ports, and with only that change the output went to 367 HP@5,200 RPM, and 420 ft/lbs @ 4,000 RPM.
