Re: MEGA BLOCK ?
[Re: Ari440]
#946592
03/08/11 10:21 PM
03/08/11 10:21 PM
I think that would be a 622"
Re: MEGA BLOCK ?
[Re: Ari440]
#946599
03/08/11 11:08 PM
03/08/11 11:08 PM
Posts: 295 Greensburg, Pa
Mpetros
Greensburg, Pa
The 4.5 bore x 4.625 is 604
Nope 4.5 bore with a 4.625 is a 588 4.5 x 4.75 is 604
how do you get a 622
are all these combos from 588 to 622 raised cam blocks
Here is a formula
Bore X Bore X Stroke X 8 X .7854 = CI
4.5 x 4.5 x 4.625 x 8 x.7854 = 588CI
4.5 x 4.5 x 4.75 x 8 x.7854 = 604CI
Re: MEGA BLOCK ?
[Re: HEMIFRED]
#946602
03/08/11 11:16 PM
03/08/11 11:16 PM
Posts: 5,618 long island NY
Ari440
long island NY
would a 622 ci be the biggest motor for a wedge/hemi thank you guys
1.39 9.85 - 137 mph
Re: MEGA BLOCK ?
[Re: Ari440]
#946603
03/08/11 11:48 PM
03/08/11 11:48 PM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
thank you guys
4.562 bore/4.875 stroke=636ci ish (what my TS engines are)
4.562 bore/5 inch stroke=650ci ishci (Good clearencing in the block needed)
Re: MEGA BLOCK ?
[Re: Ari440]
#946604
03/09/11 02:57 AM
03/09/11 02:57 AM
Posts: 791 Bama
Randy..
Bama
with a 4.500 stroke it will be 572. no chain and gear that i know of must use a belt drive or a gear drive, also been said before check the main studs make shure they are ARP and not just the nuts, i recently bought a Alum version and going thru the same thing. but i'm going 4.750 stroke.
Randy
what would the cubic inches be 588 or bigger
will be 604, think the biggest you can go with cast blocks is 654, 4.560 bore and 5.00 stroke can get more if you can go 4.600 bore.
Re: MEGA BLOCK ?
[Re: HEMIFRED]
#946605
03/09/11 12:29 PM
03/09/11 12:29 PM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
correct I own both
Fred....should we mention our friend in GA.?
